Results 1 to 10 of 10
    Feb 2013
    oilly fluid on outter rear diff area.
    hey there im new here....just got a new stampede few weeks ago.....after driving yesterday....noticed some oil spray or leak on rear diff where u have the bearing with blue seal ..think number 5119. does anyone now why or whats leaking....
    Riverton Utah
    5,319
    Welcome to the fourms! Don't worry, it's normal for some grease to leak out like that. It's coming from inside the diff, and it slowly leaks out threw the bearing. Don't worry, it can't hurt anything. The bearing is fine also, just make sure you wipe the grease off, or else dirt and crud will stick to it. Hope this helps!
    My life is busy, but I'm still lurking! 24 RC's
    Oct 2013
    9
    So as long as you keep it clean it is not a problem? What if all the grease eventually comes out?
    Stampede 4x4 VXL
    E-REVO
    Riverton Utah
    5,319
    Ya, as long as you keep it clean all should be well. Yes, after awhile the grease will get low, and you should clean out the old grease and re fill it with fresh grease.
    13,773
    Fill it with diff oil, not grease. There is a big difference in performance.
    It should not really leak out and cause a big wet spot though. Check the diff seals, and if there is more oil inside the diff bulkhead, there could be a problem with the diff o-ring.
    Ya can't polish fertilizer...
    Oct 2008
    Soldotna, Alaska
    730
    You only want diff oil inside the actual diff cup with the spider gears. It shouldn't leak from there. It's sealed with bearings and a gasket.
    You should have grease on the ring/pinion.
    Sent from my SCH-R760 using Tapatalk 2
    Using while stupid may cause serious injury.
    13,773
    exactly 8)
    Jul 2013
    South Carolina
    13
    To carry on with the Diff oil/ grease idea... Whats a good all around bashing viscosity for the rear? 10k 100k 500k? And what grease do you like on the ring and pinion, is white lithium ok?
    May 2013
    Erie, PA
    719
    30k weight in rear, 50k weight if front is the most common suggest viscosity for the diffs on the the P4de. Although tune to your liking. The thicker the oil the less slip in diff. What ever grease you like on the ring and pinion. White lithium is good. I use basic packing grease for 1:1's. Some use marine grease.
    The message above or below may or may not be true
    Wales in the UK
    6,462
    I am with hirschowl on the 50 front and 30 back because its a good balance on all surfaces dude.....peace
