    Jan 2006
    Sydney, Australia
    190
    On-board LVC required when using a LVA?
    When running a LiPo the Rustler VXL manual says that i must have the LVC on but do i need to bother if im running a LVA? I plan on setting it to alarm at around 3.5v or 3.6v...
    Alma, Michigan
    12,318
    If the ESC is LVD equipped, there is no purpose for an LVA.
    Jan 2006
    Sydney, Australia
    190
    Interesting. I've read not to rely on the Traxxas LVD as it can cut in prematurely and nobody actually knows what voltage it cuts in at anyway?
    RC Champion trax de max's Avatar
    1,915
    If you think of the LVD as the final barrier and use the alarm as a warning sign when voltage is getting low and you can set to the voltage which you'd like to stop at. I'm sure the different C ratings has an effect on what voltage the battery is at when it hits the cut off.
    Google search trumps Wiki. Refer to user guide.
    Alma, Michigan
    12,318
    C rating is a part of it, that is for sure. If the C rating is not high enough, the power system will pull more amps than the battery can provide, making voltage dip.
    Stage 1 on my Traxxas ESC's have been consistently around 3.6v and 3.4 for stage 2.
