Results 1 to 17 of 17
    RC Qualifier SkidMan's Avatar
    Quebec,Alma,Lac-St-Jean
    298
    Aluminium Gear box???
    I need aluminium gearbox for my E-Maxx Brushless(8 diff broken after 4 month)....... but after 3 month the aluminium gear box on Golden Horizon website and another website still back order.I send some email to Golden Horizon and no reply.
    Where i can get aluminium Gear Box for my E-Maxx (silver)????
    -Blue X-maxx
    -E-Maxx 60.2mph
    -Spartan 48.2mph
    Kansas
    537
    Found this link from the pros that might help: http://traxxas.com/forums/showthread...(-all-models-)
    9,244
    I ran aluminum cups and cases and they only helped out a bit ended up doing the flm hybrid 1/8 diff got tired of breaking them too
    Brookline, NH
    1,229
    Integy and gpm, makes alum cases to name a couple. e-bay Heres a link to a diff cup from hr that fits the #5382x diff gears.
    http://www.ebay.com/itm/Traxxas-Emax...item3f21dc1704
    Found these, silver
    http://www.ebay.com/itm/Differential...item2c5ea6e74c
    http://www.ebay.com/itm/iNTEGY-Alloy...item256eecbc2a
    But like 50 said, You still have the weaker stock gears and the little pinion bearings that are prone to fail.
    hope this helps.
    749
    can you tell me what the flm hybrid 1/8 diff is? i have broke about 3 diffs now and sick of it. could you please link me to where i could purchase it if indeed it is much stronger? thanks
    Brookline, NH
    1,229
    Its a bulkhead and gearbox combined into one unit. It uses the stronger 1/8th scale gears. and bigger bearings.
    http://www.fastlanemachine.net/prodd...LM17750&cat=15
    You can get them with or w/out the diff.
    749
    Quote Originally Posted by EMAXXBRUSHLESS View Post
    Is that for the front only? I only have a problem with my rear diffs breaking
    9,244
    and don't forget the spider gears . i have went through a few sets of those .stock has 4 gears and 1/8 scale has 6 gears
    9,244
    They have a different final drive you will need to.replace front and rear
    298
    Did the traxxas CVD work with the FLM gearbox???And with the FLM 1/8 setup my top speed will be affected???
    @EMAXXBRUSHLESS
    The gearbox link it's for the old E-Maxx diff..... i need the case for the new E-Maxx diff (3908-3905-3903)
    -Blue X-maxx
    -E-Maxx 60.2mph
    -Spartan 48.2mph
    9,244
    You will loose some top end but can gear up a bit
    For the center traxxas cvd we did the washer mod into a losi cup with the 8mm pinion but if you buy the combo from flm theirs have a turned down pinion
    Brookline, NH
    1,229
    298
    Thanks!!
    -Blue X-maxx
    -E-Maxx 60.2mph
    -Spartan 48.2mph
    Albany, New York
    489
    There was one on ebay by GH racing but it sold...i was going to buy it ..it was only like $15 with shipping brand new.......i think your best consideration would be getting the FLM Hybrid Ultimate Bulks.......
    298
    I bought 2 Integy gearbox (thanks EMAXXBRUSHLESS).
    If my diff broke after that i will check for the FLM Hybrid Ultimate Bulks !!!!
    -Blue X-maxx
    -E-Maxx 60.2mph
    -Spartan 48.2mph
    Brookline, NH
    1,229
    Glad to help. I bought the same ones for my other maxx and the hr alum diff cups. Only used a couple times since so time will tell how they hold up. 6s is hard on stock diffs. I will stick with 4s for that truck. I had to do a little scraping on mine to get the bearings in,but no big deal. They also come with a bearing shim that alows you to use a 10x16mm bearing instead of the 10x 15mm. I didnt break the diff gears on mine it was the pinion bearings that failed and chewed up the ring and pinion on both. So some good pinion bearings wouldnt hurt. I used avid bearings,but theres better ones. Ceramic,ect.
    298
    Yep 6S is hard for the diff......i run my E-Maxx on 4 and 6S (50/50) with proline paddle.
    -Blue X-maxx
    -E-Maxx 60.2mph
    -Spartan 48.2mph
