Page 2 of 2 FirstFirst 12
Results 41 to 75 of 75
Thread: 4 Stroke Revo
  1. #41
    Biggest Little City In The World
    737
    Edar1 what kind of welder are you using, mig or tig? Im really tempted to build my own cage but i only have a wire feed.
    "You just got passed by a Traxxas"
  2. #42
    milwaukee wisconsin
    169
    so did you get the external rolecage idea from the summit?
  3. #43
    Feb 2013
    Burnt fork, Wyoming
    68
    So my GF has been dieing to paint the body and I even let her pick out the colors for it. This a now a practice body cause all the welding has burnt it. But just to see how it would look we painted it any way and here it is.
    Now we have a problem she wants the roll cage to be painted black. Like this little pace I painted to get a idea of the look.
    I want to paint the roll cage the same green as the body like this.
    What do you guys think Black or Green???
    Friends don't let friends drive stock.
  4. #44
    Feb 2013
    Burnt fork, Wyoming
    68
    I have a mig like yours it is a wire feed if you look on the inside it should tell you what to set it at for the size of metal your are welding. I used 3/16 wire so I set the welder to 42 wire speed and 3 on the power setting but check to see it that is where yours needs to be and get some extra wire and practice with it. I have wanted to do one for years but did not have a welder till now.
  5. #45
    Jul 2011
    S. Jersey
    784
    I vote black. The green looks good too but not around the fender flairs IMO. Great build by the way.
    Jato 3.3, Revo .28 JL Max, Nitro Stampede 3.3
  6. #46
    737
    Quote Originally Posted by edar1 View Post
    Are you using flux core wire or a shielding gas? I have both just need to fill my gas bottle. If you use flux core ill save me some money and not buy gas. I normally just use C02 but may get Argon cause it splatters less.
  7. #47
    Feb 2013
    Burnt fork, Wyoming
    68
    I used Shielded gas with Argon I have used CO2 before but like the Argon better. Good luck and post some pic's so we can see your roll cage.
  8. #48
    Sep 2012
    72
    I prefer black.
  9. #49
    Apr 2009
    New Hampshire
    81
    I'd definitly go with the black the contrast looks sick.
    I NEED CHEAPER HOBBIES!
  10. #50
    Feb 2013
    Burnt fork, Wyoming
    68
    Not much to report on been busy with work and the GF.. I am trying to find a clutch bell that has metric BB, 13 or 14 tooth and a pitch of 32 or .8 mm and I dont care what size the bell is. I plain on welding it to a bigger bell so if any one know of something that might work let me know so I can check in to it. On a side note I did get the other gas can in and JB welded the exhaust stack.
    I have as been working on the vacuum forming for the cooling shroud and duct work, but so far all I have managed to do is spend money on more lexan and a heater on and on . I will let you guys know when I it right and how I did it. I hope to get the tranny set up with the Jato gear I have for it. I have to lift the tranny to get the new spur gear to clear the chassis.
  11. #51
    Jun 2009
    Minnesota, hey look it's snowing again...
    426
    Here's an idea. See if you can find the spur gear you want in mod 1 pitch, don't worry about the bolt pattern for the moment. Since you're making a crawler, you could probably get away with not having a slipper clutch on your spur gear. Use the space that the slipper used to occupy to make a custom adapter to bolt on the new spur gear. Or you could just make a new plate for the slipper with a different bolt pattern for the new spur you find.
    Hope this helps
    al'Thor
    Suzuki
    Way of Life!
  12. #52
    Feb 2013
    Burnt fork, Wyoming
    68
    I cut out the gas tank mount and bent the brass for the fuel lines to run inside the bumper.
    I then I figured I would weld up my own bell, so going with the 0.8m I got a summit spur and cut the frame to clear the gear.
  13. #53
    Feb 2013
    Burnt fork, Wyoming
    68
    More parts for the build... got the perry pump and T fitting so there is no need for a back pressure line. The rebuild kit for the motor minus the connecting rod, A 3.3 reverse gear, new boots. Thats right to top it all off Summit locking diffs.
    I have also been working on my vacuum forming and had some successes with it. This is the side of the engine cooling shroud.
    As well as a lot of failure... or as I like to say is a lot of learning lessons. The other half of the cooling shroud.
    On the bright side I am getting closer to what I want.
    When I get the frame cleared out for the locking diffs I will post some more pics.
    Thank guys
  14. #54
    Feb 2013
    Burnt fork, Wyoming
    68
    I have done some sanding on the frame
    and cleared the frame for the diff lockers
    I have also been working on the cooling shroud and still messing up on them
    but after working on the molds i got good vacuums out of them
  15. #55
    Feb 2013
    Burnt fork, Wyoming
    68
    The hole shroud aft of the cooling duct
    this is still in the mock up state and could have to change do to spur gear might not clear.
  16. #56
    Jul 2012
    Yakima, Washington
    1,440
    that is very creative ^^^ good job
    i wonder how well it will help with heat
  17. #57
    Sep 2012
    72
    very nice job!
  18. #58
    Feb 2013
    Burnt fork, Wyoming
    68
    It should work just like a Heli engine they have cooling shrouds to keep them under temp. That is where i got the idea from I will put a Y harness on the throttle and plug in a esc for the cooling motor. So as i rev up the engine it will bring up the rpms on the cooling motor and should keep the temps down. I will be checking all of this through the telematry system that I have to go on it, this way i can check everything while it is running.
  19. #59
    Mar 2009
    1,974
    it does not work like that... the throttle input or any input for tat matter on your receiver does not regulate voltage for speed or direction... the signal input does that... servos work off of duty cycle, the motor will get constant 6 volts regardless of init...
    you know.. i never had a sig.. but i do now...
  20. #60
    Aug 2012
    78
    He is using an esc.
  21. #61
    Mar 2009
    1,974
    oh my bad.. missed that
  22. #62
    Feb 2013
    Burnt fork, Wyoming
    68
    So I have been working on a new cooling shroud as the old one did not clear the spur gear.
    I also mounted the tranny with spacers under it to get good gear mesh and make sure that the new shroud will clear.
  23. #63
    Feb 2013
    Burnt fork, Wyoming
    68
    Rather then having a bolt together flange like the old shroud I am putting the cooling fan mount and motor shroud all one mold.
  24. #64
    Feb 2013
    Parker, CO
    1,157
    any updates on this build? super cool stuff!
    I have an RC problem...
  25. #65
    Jul 2013
    30
    awesome job!
  26. #66
    Jun 2007
    Farmingville, NY
    678
    WOW. Id love a fuelie Revo like HPI was been working on with the savage octane...
    Traxxas please sell kits!
  27. #67
    Nov 2013
    27
    Idk how old this is but it's way cool
  28. #68
    Feb 2013
    Burnt fork, Wyoming
    68
    Well fans it has been some time sense I have touched this project but fear not I am back to work with some additions. After a move to a new house and job as well as getting the hobby room set up. Now that it is winter and things slowed down I have dusted off the box and been ordering parts. I hope to soon have pic up on the progress.
  29. #69
    Jun 2007
    Farmingville, NY
    678
    glad to see your back at this build..... this is so far beyond my scope of abilities im in awe seeing the thread.
  30. #70
    Sep 2012
    somewere in ohio bashing a traxxas
    197
    Dude! I'm subscribed! Awesome build so far, I wish I had the funds to do stuff like this.
  31. #71
    Nov 2013
    210
    any updates?
  32. #72
    Feb 2013
    Burnt fork, Wyoming
    68
    So I have been busy with work but now I'm back at it I've got the frame assembled locking differentials are installed with the special little arm that is required. here is a photo of my custom clutch bell but I'm going to have to do it over as some of the slag from welding got into the gears.
    So it took two clutch bells to make one and here is what i made
    The new wooden vacume mold for the cooling shroud I have finished molding and sanding it i need to coat it in epoxy and build the base for it then vacume the shroud
    it feels like every time i put the chassis together to test fit something the next part i put on i end up ripping half of the chassis parts off the get the fit I need... I am now installing the shift linkage from a summit for the locking diffs and had to pull the tranny so i could lay it out and rebend the linkage to fit a revo frame.
  33. #73
    Feb 2013
    Burnt fork, Wyoming
    68
    Does any one know of a alloy after market slipper clutch with the summit spur gear i have on my tranny it rubs on the tranny case as all the traxxas slipper wobbles back and forth ans the spin. The stock set up works ok but for what I am doing it is a problem. I could put a washer under the side of the spur gear to space it up but would like to make it right. Thanks Guy. Side note I have been working on vacuum forming the new cooling shroud with thicker lexan and it is not working out so well. When I have any major progress I will post pic's.
  34. #74
    RC Qualifier dr frankenstyle's Avatar
    Dec 2013
    Rural MO ... in a haunted garage
    310
    First, AWESOME truck !! I built a crawler from a revo, not quite the "scaler" you're building, but some similarities. I cut a 3.3 chassis a bit more than yours and mod'ed the motor mount outboard to get clearance to run a 14t cb and 72 spur from a Tmaxx. 32 pitch, ready to mount to the revo tranny :-) Still a bit too fast for serious crawling, but TONS of fun on the rocks. The 3.3 chassis let me mount 2 micro-servos to control the t-lock diff's. I LOVE IT!! Can't wait to see yours finished !!
  35. #75
    Feb 2013
    Parker, CO
    1,157
    Would love to see an update. OP hasn't been on line for 2+ years
