Thread: 1642mah/3800mah
    Cortland
    116
    1642mah/3800mah
    Is it bad that my Lipo just charged and only took 1642mah after a full run? Does it mean the battery is on its way out? It shouldn't take a full 3800mah right?
    Alma, Michigan
    12,314
    It should not take a full 3800mAh, no. You only actually get to use about 80% of the packs rated capacity... so about 3000mAh.
    If it is only taking that much, I would stop using the pack.
    A good way to test is to discharge it on your charger to about 3.2v/cell and then fully balance charge it to see how many mAh are really getting into the pack. Some LVD ESC's cut off pretty high.
    Cortland
    116
    Well I'm using an onyx 245 and don't have the option to discharge with the charger. When first plugged in it read 7.6v. That should be 3.8v per cell. My truck has the vxl-3s/velineon in it.
    Alma, Michigan
    12,314
    3.8v is only about half of it's usable capacity... actually, it is basically storage voltage.
    Cortland
    116
    Well I just read a thread about issues in the cold. It's was cold in ny and I was in a little snow. Would this cause the esc to have a false lvd reading that made me think the battery was dead?
    Alma, Michigan
    12,314
    Yes, it would.
    But it is actually hitting LVD... cold effects the C rate. Which means when you try to pull amperage out of the pack it can no longer produce due to the cold, voltage dips and trips the LVD.
    Zeeland Michigan
    1,230
    Quote Originally Posted by exrider720 View Post
    I've the same setup , a Onyx 245 an the vxl-3s/velineon system and my esc cutoff is right at 3.65 per cell , I've to charge the battery a little to bring it up to 3.85 per cell . To discharge I use a auto build with a lvd with buzzer set at 3.9v then watch it till it at 3.85 . Hope this helps. I run 3s 11.1v 25c 5000mah power cells .
    1 Rusty VXL
