    66
    Front end rebuild help
    I did the rear diff last week and today decided to do the front end however hit a couple of snage putting it back together.
    Firstly why the big gap on the left wishbone?
    Secondly can anyone tell me where these go on the hinge pins?
    Pics would be very helpful
    muscoda, wi
    1,245
    4 shims go on the upper front a-arm. im loading a pic quick. the a-arm is all the way forward, and 4 shims go on the end of the pin that goes throught the upper front arm.
    this is on the stock summit front bulk/arms. that might fix your gap to. other side also needs 4 shims. so you need 8 total.
    Norfolk, va
    1,164
    There is 1 screw that holds the bulkhead together for assembly.
    Diff might be installed upside down, or not aligned right in the slots.
    If everything is installed right, just squeeze the bulkheads together.
    ERBE, ERBE, Summit, Slash 4X4, Bandit,
    66
    I put 2 on upper front arm arm and there's still loads of slack
    and the other side there's heaps of slack, I have 8 shims in total
    muscoda, wi
    1,245
    Quote Originally Posted by DayWalker View Post
    yes, your top pic shows 2 shims. it needs 4. plus in lower pic. you see the pin gap in front. it should stay bare. mine is stock, and i see the whole gap. dont know why traxxas didnt put shims there also. its only that side of bulkhead that shows a gap on the front.
    Norfolk, va
    1,164
    The shims are used to set your caster, you can put all 4 together, or 1 and 3, 2 and 2, etc.. As long as 4 are used on each corner.
    66
    ajcar your a life saver think i've got it right now
    i truly thought i was going mad lol
    oh and to top it off....
    dont you hate it when you have a single bolt left over thing is I don't remember taking it out it just appeared from no where. Will have to try and find the part number.
    muscoda, wi
    1,245
    good, glad to help. i learned alot on this forum. so im happy to share some help along the way. peace, and have fun. i know what your talking about having a extra screw after a rebuild.
