Results 1 to 2 of 2
    slipper clutch or center diff assembly maintenance
    I have the Slash 4x4 Ultimate, run mostly on soft dirt / damp track. Have cleaned and reversed my axles
    ( male / female), also read that frequent & good maintenance should performed on the slipper clutch and or the center differential. I am running the center diff. Could you guys tell me how often & explain what to look for, etc. Thanks.
    you need to clean and re grease the center bearing. they tend to lock up, and if they do on a center diff, the diff case will be shot. if i were you id go pick up a few bearings and if that bearing ever feels a bit gritty replace it.
