Results 1 to 14 of 14
    14
    Just got my mamba max pro sct 2400kv
    Hey I just recieved my Castle Creations 1/10 Mamba Max Pro SCT 2400kV System. I'm wondering what 4s lipo fits the traxxas rally.
    11,223
    You can put 2X 2S hardcase lipos on their side and use a series connector. That works and has the added benefit of being 2 pack that fit other vehicles.
    14
    ok I might try that. Is there any 4s lipos that fit?
    7,264
    this is what i use and fits perfect with extra room to put a foam to keep it from sliding around.
    http://www.hobbypartz.com/77p-sl5000-4s1p-40c-4444.html
    too bad their out of stock or i would have order another one, but the 4000mah is available if you dont mind the runtime a bit short than the 5000mah, i get a good 35mins on my 5000mah.
    dont forget to buy the tall battery hold.
    14
    Does anyone have any tips on installing this motor/esc?
    Sep 2010
    the giant boot. Anybody?
    2,726
    Move the receiver box to the front shock tower. There are 2 hole's for it to attach. You can get a custom plate for the esc from STRC and it will bolt right up and attach the esc with servo tape. Install the motor so the wire's are facing up or to 10 oclock. Set mesh as you would with any other motor and off you go. I run this combo on 4s in my slash 4x4 and use 60% punch control and still see standing back flip's.
    14
    How is the reciever held in place. My guess is two sided tape. Figured I would ask before I broke something. I ordered the STRC esc plate and servo tape
    7,264
    Quote Originally Posted by jeremy-farrar View Post
    are you talking about the reciever box? if its the box its secured with two screws from the inside to the chassis.
    7,173
    At first I moved the Rx box to the front of the chassis. Once I got everything situated I moved it back to the bottom of the pan. It fits perfect and snug. I cut a piece of lexan to fit and drilled holes where it bolted down on the chassis, then mounted it to that plate using 3m double sided tape.
    I thought I had a better shot of it. Here is one more, but shows mainly the motor.
    I need to snap some better updated shots.
    Weak Revenge
    Strong Forgive
    Intelligent Ignore
    14
    im talking about the reciever it self. The screws are underneath the reciever. I cant get the reciever out to get to the screws.
    Sep 2010
    2,726
    Oh, you have to use a thin flat head and pry the receiver off the inside of the receiver box. Just go gentle and work from the side's in and it will pop off.
    South of St Louis
    6,101
    I'll test-fit my 4s Gens Ace tonight and let you know.
    14
    Quote Originally Posted by I EAT DIRT View Post
    I thought it was stuck on there. I just wanted to be sure before I broke something.
    7,173
    My bad. Yest it is kept in place by Rx tape. Carefully pry it off with a flat head w/o breaking the Rx box.
    Weak Revenge
    Strong Forgive
    Intelligent Ignore
