Results 1 to 11 of 11
    canada
    41
    summit wheelies !!!
    i was wondering what it would take to make a mini summit do wheelies
    i have the progressive rockers that i can install
    i dont no what else i need ?
    Buffalo NY
    1,330
    Have you tried tightening your slipper clutch?
    Also, what batteries are you running?
    canada
    41
    i am running two stock batteries in parallel and this really isn't a problem its just something i would like to be able to do, you know its just funner
    Dec 2006
    Argentina
    4,655
    Flip your tranny...
    He Who Dies With the Most Toys Wins.
    RC Champion dcfox's Avatar
    SE Texas
    1,202
    I can hardly keep mine from doing wheelies...and it's bone stock.
    Have you tried a single 2s Lipo?
    "Dude,I almost had you"
    R.I.P Paul Walker
    Woodward, OK
    752
    Quote Originally Posted by Demigod15 View Post
    Do you have a brushed or brushless? I am assuming you have brushed, because I can not figure out how you could keep a brushless version from doing wheelies. Unless you were geared really high on the pinion, like in the uppper twenties or something.
    Rusty 2.5R,T-max 2.5 & 3.3,Summit VXL Nitro 4-tec
    canada
    41
    i have not tried a lipo and i dont really intend to
    and its a brushless edition
    it might be beacause of the snow and ice but i dont think so
    i was also wondering if a smaller pinion makes it go faster, or the oposite
    and what gearing to use
    Woodward, OK
    752
    What gear are you running on your pinion? 16 pinion, and 55 spur are stock. I run 18/55 with no heat issues, unless I am running in heavy grass. With 2s lipo, at about half throttle, I can pop a wheelie on a good surface. A smaller pinion will make it go slower top end, but have more exceration. A bigger pinion will make it go faster, with less exceration.
    canada
    41
    I am running stock pinion and stock batteries in parallel but i have a 19t pinion on hand
    What pinion should i use for Speed ? Is changing the spur something i should do?
    Woodward, OK
    752
    You could go with the 19, maybe not good if you are running snow and ice. Good for speed runs on pavement. Mine mostly runs on pavement, hard packed dirt, or short grass. You would want to keep an eye on your temps with a temp gun. I dont make to many long speed runs, back to back, so I can get away with the 18. I think the only other spur is a 50, which would give you even more top speed, with out gearing down on your pinion.
    canada
    41
    Cool that should work. I'll try when the snow melts
    That should be in about 2 months
