    S.E. Iowa
    179
    lubing up an old motor
    what can a guy run through an old engine (2.5) that has been sitting for 6 plus years. I got it free but wondered if I could dump a little oil of some sort in there and really lube it up or just run wd through it
    Jan 2008
    Sugar Hill Ga.
    8,397
    Used engine sitting for 6 years; I would disassemble it and give it a good cleaning, check bearings and look for rust.
    If it has rust and you fire it up, the rust will become dislodged and cause wear to the piston/sleeve as it circulates out through the engine. Better safe than sorry.
    S.E. Iowa
    179
    that makes complete sense, from sitting in the car it looks to be pretty clean and looks pretty clear through the manifold. I tried to remove the engine but not having much luck and don't want to take any more apart than needed. this is an old rustler and I searched through the support link and there is nothing to assist me in removing this motor.
    S.E. Iowa
    179
    I got it out, pretty amazed how clean it is, must have done a good after run when I put it away ehh
    S.E. Iowa
    179
    you was right snook , I decided to get brave and tear things down to find rust behind the scenes .
