    5
    pinion gear removal?
    Hi.
    Is there a trick to pinion gear removal? I've removed the grub screw that holds it in place but cannot budge it from the motor shaft.
    Philly area
    507
    There is nothing else holding it in there. Did the screw snap off inside?
    5
    I don't think so. Was able to remove screw with no problem. Gear seems fused to shaft...
    Austin, Texas
    970
    I would take the motor out and lightly put pliers on the part of the pinion without the gear and wiggle it slowly.
    RC Champion soundmaster's Avatar
    2,226
    maybe some loctide left over. try to apply some heat to the pineon and pull it off.
