Page 2 of 5 FirstFirst 1234 ... LastLast
Results 41 to 80 of 189
  1. #41
    Michigan
    1,118
    Quote Originally Posted by stampede_fanatic View Post
    I was actually thinking of doing that for my next project. Where is a good place to buy rit dye? K-mart? Walmart? Target?
    I found some black rit dye at my local Walmart in the the laundry detergent section.
    Stampede 4x4
    Anza Slash VXL
    Rustler VXL
  2. #42
    USA
    571
    Quote Originally Posted by dgudenau View Post
    Will check Walmart out this weekend.
    Thanks man!
  3. #43
    360
    I found mine at Kmart. I did my Slash and pede at the same time. Used the whole packet and left the bodies in hot water for a little ovwr an hour. Gives the truck such a new look. Totally worth it!
    -Slash 4x4 MT 2000kv
    -Slash 4x4 MT 2100kv
  4. #44
    USA
    571
    Quote Originally Posted by Pede Pede View Post
    Will check kmart out this weekend as well. I'll compare which one sells it the cheapest. Thanks!
    Btw, I just boil water until very hot, pour whole packet of rit dye, soak chassis a little over an hour and I'm all set right? Do I need to add anything on the hot water besides the rit dye?
  5. #45
    360
    Pretty much, yes thats what you do. I put two pots on the stove and put one body in each so as the water got hot, so do did the bodies. I believe already having the bodies hot before putting them in the dyed water helps the dye stick to the body better.
    Put the packet in the hot water, stir it a little, put the body in and cover the pot or bucket to retain the heat. Just make sure you thoroughly clean the body of all dirt before hand. I paid around $2.29 at kmart if I recall correctly.
  6. #46
    USA
    571
    Cool! Thanks for the advice man.
    Updates! Installed Tekno Rears and MIP front CVD axles yesterday.
    Before Tekno Rears:
    Right side done:
    Close up of right side cup:
    Both sides done:
    With wheels on:
    Right side close up:
    Left side close up:
    What the rear looks like with wheelie bar on:
    Front with stock axles:
    Front with MIP CVD axles installed:
    Quick recap on "Blue Bayou's" mods:
    -->Blue RPM A-Arms (Fronts) - DONE!
    -->Outerwears Shroud - DONE!
    -->DIY Lid lowering - DONE!
    -->T-Bone racing front bumper and Servo Guard - DONE!
    -->Aluminum Bearing Adapter - DONE!
    -->Kingheadz motor mount - DONE!
    -->Blue Aluminum Bearing Carriers - DONE!
    -->Blue RPM A-Arms (Rear) - DONE!
    -->Blue Aluminum Steering knuckles - DONE!
    -->Blue Aluminum Caster Blocks - DONE!
    -->Rear Teknos - DONE!
    -->Front MIP CVD's - DONE!
    Upcoming mods:
    -->ICE AMPS Blower System from RB Innovations
    -->ESC Fan
    Projects:
    -->Plastidipped Talons in Black - DONE!
    Upcoming projects:
    -->Chassis Dye, Black
  7. #47
    United Kingdom
    629
    Looking good.
  8. #48
    USA
    571
    Quote Originally Posted by o0wiz0o View Post
    Looking good.
    Thanks man!
  9. #49
    Wales in the UK
    6,436
    You are doing a sweet job on your pede dude it wont be long before you run out of stuff to do to it but bash hard and fast man.....peace
  10. #50
    360
    Stampede_Fanatic, please let us know how that ice blower works out if and when you get one. I did consider buying one but there are things about it that I dont like. For example, I wish they made ducts at the bottom or side to direct the air out, I also wish they would have incorporated some sort of fins on the mount to aid in heat dissipation. I went to the only place that sells it that I know of, the manufacturer, and after putting the item in the shopping cart and having the tax and shipping estimated, the total was $52.......No.Thanks.
  11. #51
    USA
    571
