Page 5 of 5 FirstFirst ... 345
Results 161 to 189 of 189
  1. #161
    RC Champion dgudenau's Avatar
    Michigan
    1,176
    Quote Originally Posted by Myself View Post
    Hi!, Im new to the forum and to rc . I'd like to know which of the upgrades needed more than say...a screwdriver,...I'm serious. Thanks
    Most upgrades aren't hard to install due to the simple construction of the p4de(I think its eight screws and you have the front clip, rear clip, and chassis separated). You probably need a good set of hex drivers to make installations easy. (Like these: http://www.hobbywarehouse.com/s.nl?i...msla=T&whence=) The hardest parts to reach and service are probably the diffs.
    Anza Slash VXL
    Rustler VXL
  2. #162
    USA
    571
    dgudenau basically summed it all up for me. Thanks dgudenau!
    Quote Originally Posted by dgudenau View Post
    I want an avatar... 3000 posts here we go!
  3. #163
    May 2013
    31
    Thank you two very much. I'll get a set of good tools first. Cheers.
  4. #164
    USA
    571
    I've finally decided it was time for "Blue Bayou's" mods to stop. I've modded it every way possible and I love the way it is right now.
    Keep a lookout for "Blue Bayou's" nemesis "The Rollin' Tomato". This truck will be a faster, tougher, and meaner than the first.
    Basic mods on "The Rollin' Tomato" will be there (Alum bearing adapter, Kingheadz motor mount, rear bearing carriers, steering blocks, steering knuckles, RPM a-arms, etc), BUT I will start doing mods I have never done before like installing a castle motor, using pro-line's protrac suspension kit, using different shocks, different type of wheels etc.
    Will keep you guys posted on that!
    I'm basically going a different route on hop-up parts for the next build. In that way, I can compare which one is better in handling and whether one is superior than the other when it comes to bashability.
  5. #165
    14
    This is the Nicest RC Ive ever seen.
    Sick build...I love it with the mashers!
  6. #166
    May 2013
    29
    Where did u get the huge fan?
  7. #167
    USA
    571
    Quote Originally Posted by lazz View Post
    Thank you so much for the compliments.
    Quote Originally Posted by Brushless boy View Post
    I got it from ebay. Search "EZRUN 5V Cooling Fan & 36 x 55mm Motor Heat Sink AC225"
    Desperado's finally stripped, so I did the following:
    Before:
    After:
    I upgraded the wheel hexes from 12mm to 17mm.
    Quick recap on "Blue Bayou's" mods:
    -->Blue RPM A-Arms (Fronts) - DONE!
    -->Outerwears Shroud - DONE!
    -->DIY Lid lowering - DONE!
    -->T-Bone racing front bumper and Servo Guard - DONE!
    -->Aluminum Bearing Adapter - DONE!
    -->Kingheadz motor mount - DONE!
    -->Blue Aluminum Bearing Carriers - DONE!
    -->Blue RPM A-Arms (Rear) - DONE!
    -->Blue Aluminum Steering knuckles - DONE!
    -->Blue Aluminum Caster Blocks - DONE!
    -->Rear Teknos - DONE!
    -->Front MIP CVD's - DONE!
    -->ESC Fan - DONE!
    -->Motor fan - DONE!
    -->Aftermarket shocks - DONE!
    -->Better wheels and tires- DONE!
    -->Sway Bars - DONE!
    -->Aluminum hexes - DONE!
    -->Stiffer shocks with 50 wt shock oil - DONE!
    -->jconcepts F150 raptor body - DONE!
    -->Shock Covers (Blue) - DONE!
    -->G-Loc tires for speed runs - DONE!
    -->Clear gear cover - DONE!
    -->Revo slipper clutch upgrade - DONE!
    -->T-bone racing rear bumper with wheelie bar - DONE!
    -->Mega fan with heatsink for the summer - DONE!
    -->17mm wheel hexes - DONE!
    Upcoming mods:
    -->Castle 2400kv motor (Finally decided that this MOD is going to the "Rollin' Tomato").
    Projects:
    -->Plastidipped Talons in Black - DONE!
    -->Chassis Dye, Black - DONE!
    -->Wire Mesh over ESC - DONE!
  8. #168
    USA
    230
    Nice, me too mine are in the mail!
  9. #169
    USA
    571
    Quote Originally Posted by makuloco2000 View Post
    Thanks!
    I can't wait to try them out!
  10. #170
    Wales in the UK
    6,462
    It keeps getting better and better every time I see your posts dude hope you are well man.......peace
  11. #171
    USA
    571
    Thanks man!
    Btw... UPDATE! 4th of July Project. Doing this before the visitors arrive. LOL!
    I decided to do some body reinforcing since the body post on the right side of my pede broke through body/lid. Here's a pic:
    Cut the drywall fiberglass tape into this shape (Made 2 of them. One for each body mount holes on the hood):
    Put some shoe goo on the body first to make the already cut drywall fiberglass tape stick on the body mount holes (I really didn't care much for some of the shoe goo that got into the hood since this is my bashing body):
    This is what the cut drywall fiberglass tape looks like after applying a coat of shoe goo:
    I applied another coat of shoe goo until it covered all the drywall fiberglass tape. After that I put the body washer on top. Used a body reamer (Sharp looking thing, circled in red) so I can make the body washer go in-line with the body mount holes. Did that for both sides:
    Applied some shoe goo on top of the body washers, cut another set of drywall fiberglass tape and stick them on top of the body washers:
    Applied final coat of shoe goo. Once this dries, that will be one tough body hole mount.
    Here's an after pic (IMHO, not much has changed since it looks the same as the before pic, but underneath that is one tough body mount hole!
    More pics on next post...
    For reference, this is what the rear looks like. I did this 3 months ago. After doing this mod in the rear, the body mount holes never cracked. I can say that it's so tough that the body mount holes were not able to go through it to this day! Take note, that I bash very hard with a lot of flips and cartwheels:
    Pic of how the bed it looks like with the reinforcements done (You can actually see a little bit of the white body washers):
    Materials used. Drywall fiberglass tape, shoe goo, body reamer (Shoe goo and drywall fiberglass tape can be bought in your local hardware store. Body reamer I got it on ebay for cheap):
    Here is a pic of the underside with reinforcements done. I just have to wait for the newly reinforced hood to dry, use a body reamer to bring out the original body mounting holes and I'm all set again for another bashing day! Voila! There you have it.
  12. #172
    Wales in the UK
    6,462
    Looks like it will fight another day man good work......peace
  13. #173
    USA
    571
    Thanks man!
    Hoping for another 50+ runs...
  14. #174
    McKinney, Texas
    811
    Quote Originally Posted by stampede_fanatic View Post
    Before:
    After:
    -->ESC Fan - DONE!
    Upcoming mods:
    Projects:
    The steel CVDS what brand and what brand 17mm hex adapters? If possible part numbers would be great thanks.
  15. #175
    USA
    571
    Quote Originally Posted by jtalaue View Post
    Steel CVD's: From teknorc.com Part num: TKR6852X
    17mm Hex adapters: From teknorc.com Part num: TKR1654-17
    Both work really great!
    With the old lid on (Super first stampede 4x4). IMHO, it still looks good.
  16. #176
    Temecula,CA
    2,148
    Looks good man!
    Slash 4x4 LCG+(rolling)HCG, Slash 2wd(raptor)
  17. #177
    Wales in the UK
    6,462
    Looks sick dude how is the esc and motor combo working for you now bro??.....peace
  18. #178
    USA
    571
    Quote Originally Posted by sean1214 View Post
    Looks good man!
    Thanks!
    Thanks!
    Still waiting on a few parts on that build.
    Will be updating that next week.
  19. #179
    Michigan
    1,176
    That old stampede shell looks pretty neat! What wheels are you using?
    Anza Slash VXL
    Rustler VXL
  20. #180
    USA
    571
    Thanks man!
    Those wheels are 3.2 RPM Revolver wheels with the stablemaxx offset. Those wheels along with the 2.8 proline mashers make the best combo for bashing. The mashers really have good grip on dirt, gravel, and even asphalt! My preferred bashing tire, even better than the 2.8 proline trenchers I had before.
  21. #181
    Michigan
    1,176
    Thanks man!
    Did you use the same method to mount them as you did on your rollin tomato build?
    Anza Slash VXL
    Rustler VXL
  22. #182
    USA
    571
    Yes, I used the same method as that build. Had more than 10 runs on 3S with this stampede. NO PROBLEMS so far.
    Btw, updates will be coming for the rollin' tomato pretty soon. Just waiting for some parts to arrive.
  23. #183
    May 2013
    53
    Your truck looks really awesome. I just finished my slash 4x4 build MM2 2200kv but now I feel like I want Stampede too hehe. Good job man!
  24. #184
    USA
    571
    Quote Originally Posted by Jednoreki View Post
    Thank you so much for the compliment man!
  25. #185
    Wales in the UK
    6,462
    Looking forward to seeing the finished product dude its going to be sick man......peace
  26. #186
    USA
    571
    It's a non-stop process man.
    Btw, I went to a lake nearby a few weeks back and did some bashing on gravel and mud. It was really fun doing it since I went WOT on the straightaways, did some flips and also hydroplaned on the water. Got it wet, dirty, muddy, grimy, and after about 5 hours of leaving it in the car, almost of all the bearings and some of the screws were RUSTED! I knew this was going to happen, but didn't expect it to be this bad. I will say this, I WILL NOT BASH NEAR/IN WATER AGAIN! It was really fun bashing, but taking stuff apart after made it a PITA. Most of the bearings seized so they were really difficult to remove especially the ones on the aluminum steering blocks (Take note, this was just after 5 hours of leaving the pede in the car). I had to use a lot of WD-40, and did some knocking with a mallet just to loosen the bearings up. Anyways, I took the pede apart on the SAME DAY, bagged the parts it looked like this:
    Been wanting to get some "Bling" for the pede ever since I got it so I went to ebay and got this for cheap:
    In case of any ACCIDENTAL water submersion, I will be ready for it.
    Will be installing this tonight!
  27. #187
    Bexhill, England
    434
    Same here, i used to do quite a lot of mud and water driving, but i just can't be bothered to spend ages cleaning out the truck, so now i'm a fair weather basher! If the weather is bad we meet in our church hall with quad-copters, drifters and 1/18's
  28. #188
    USA
    571
    Quote Originally Posted by cossack4 View Post
    The take apart and cleaning process is really a pain. I really won't be bashing in places where the pede will get wet... EVER! Btw, my brother is getting into quad copters, what is a good starter quad copter?
    Last edited by cooleocool; 08-26-2013 at 09:28 AM. Reason: Bypassing the language filter and non-Traxxas R/C
  29. #189
    Wales in the UK
    6,462
    I never like bashing in the rain because it would add to much down time on the pede and extra money for parts that will rust and with having 3 kids it would not be fair on them too.....peace
