Results 1 to 17 of 17
    magnolia tx
    32
    opti-drive problems
    i'm having some issues with the opti-drive on my revo, the throttle control drops out when driving and the red light on the opti drive comes on . then it goes off and the truck takes off again for a few seconds and then the red light again. also the throttle servo acts erratic when the motor is off, jumping back and forth a little bit very fast.
    still new to nitro , not sure what to do
    10,279
    Batteries charged?
    magnolia tx
    32
    fresh off the charger
    10,279
    Unplug the Opti-drive and plug the throttle servo directly into the receiver. Same problem?
    magnolia tx
    32
    havent tried that yet
    magnolia tx
    32
    took the opti drive out and it runs fine. is the opti drive bad or could it be something else
    Biggest Little City In The World
    726
    sounds like the opti drive sensor is bad
    "You just got passed by a Traxxas"
    magnolia tx
    32
    Is that an easy fix? And where is the sensor located?
    Apr 2008
    Indianapolis Indiana
    788
    That sensor sits on the front of the transmission most people just take it out because of the problems it has.
    Drive it, Break it, Upgrade it
    magnolia tx
    32
    Take out the sensor ? Or the opti-drive all together ?
    726
    The senso is right on the front of the tranny the one with the red and white wires. Its 2 screws and 1 plugs. The most you have to take apart to replace it take the battery cover off so you can unplug the opti drive plug. Me personally i like opti drive. It keep from scattering the tranny if u accidently shift into reverse going full speed. If your new Revo i recommend keeping it unless you go to forward only conversion.
    Lake Charles, LA
    66
    Go foc and ditch opti!!!! I just did and mad I waited so long.
    16
    You will find your problem probably arrises from the sensor being dirty or as such
    Revo 3.3 chassis / LRP .28
    Apr 2008
    788
    Take it out all together. You can still use reverse just remember to come to a complete stop before shifting into reverse.
    magnolia tx
    32
    What advantage do u get from the forward only concretion? Other than not having a problem with the optic drive
    10,279
    Less rotating mass so that the truck accelerates a little quicker, simpler transmission so less parts to go bad and need replacing.
    Jan 2008
    Bowie, MD
    312
    your opti-drive needs to be reprogrammed, direction in manual
    Quote Originally Posted by JEVIL View Post
    REVO DE
    2009 ROAR REGION 2 MT POINT SERIES CHAMP
