    38
    ball joint dust covers
    hi
    i just finished putting on a new set of rpm a arms front and back on my 3.3 but im having some trouble
    with the axle carrier hitting the a arm when trying to turn right.
    are the ball joint dust covers essential? would it be ok if i just sprayed wd40 in there?
    Red Deer AB
    61
    can you post a pic of the issue? As for wd-40 that might end up attracting more dust and turn it into a muddy paste in there.
    Wake Forest, NC
    406
    You can use a dry silicon spray like moo slick. The covers will keep debris from wearing out the parts quicker. Sand grinds down to dust against metal and will eventually sand the components down and create slop.
    Nitro-J-Rod
    38
    thanks for the imput, Ive actually figured out that i had the ball joints to tight so when i tried to steer the axle carriers were
    hitting the a arms
    142
    also ..., if u have rmp carriers as well u cant run ur truck with long travel or it will bind like that as well .. my first set of rpm carriers i didnt read before installing and ya totally rounded them out and had to get new ones. just thought id mention it idk if u have rpm carriers or not but just a good thing to know i think good luck
    38
    i actually have strc carriers but i think i might have had my ball joints to tight, i loosened them off and it has helped a lot
    but now they seen to have a fair bit of play, but there ok.
    142
    ya u dont want them to lose that there is slop but u dont want it to tight they dont move gotta futs a little to get it just right if found
    May 2007
    West Coast, Fl
    2,120
    Adjust your pillow balls without the shocks attached to get a better feel of free movement.
    2009 Florida State Monster Truck Champion
    RBMods
