Results 1 to 16 of 16
    9
    What Size Shims For the ERBE Diffs..?
    I want to shim my diffs on my Revo Brushless Edition but need the sizes of the shims or a shim kit with assorted shims that would work. I search Google's and many other forums and the closest size I'm seeing is 6x8x0.2 mm but I'm not sure how true that is either.
    I haven't pulled the diffs yet but I would like to know the size(s) for the both sides of the Diff and the Ring Gear or a assorted shim kit that would work.
    kansas
    8,410
    9
    87 GN.. Your my Hero..lol Thanks man, Iv'e been looking all over for this info..
    kansas
    8,410
    take you time shim'n get a good fell for the gear mesh, most times all I use are a few 6mm...
    9,244
    Question
    On the diff side you will need associated 21141
    One side is 8mm the other side is 10mm. Usually you want to shim the 8mm side to get the ring gear closer to the pinion
    9
    So it's obvious the 6mm are for the Ring gear and I take it the 10mm are for the diff..right..? Iv'e shimmed many Savage diffs so it shouldn't be a problem. Thx
    9
    Thank you 50togo that's very helpful..
    kansas
    8,410
    speaking of that other truck, how are the diffs holding up..?
    I have read of them breaking too........
    9
    I've never had a issue with the Hpi bullet proof diffs. and I've had them from when they first come out in 2008/2009ish.. The only Savage I have now is the Flux and it's a brute..
    I'm new to the Revo and herring lots of issues with these diffs. I'm only going on my 3rd run on 6s with Traxxas sway bar kit, blue springs rear & silver in front, 60wt shock oil and Big Joe's with no issues so far but I still want to shim the diffs. If for what ever reason I do bust them in the future then I may do the LST2 mod..
    9,244
    kind of a bummer traxxas has had diff problems for over ten years .started with my first t maxx in the early 2000's same problem as my revo
    May 2009
    Edmonton, Alberta
    3,632
    Sum revo's post shows 6mm on the output, and 10mm on the side outputs.
    50toGo says 8 and 10, which is it?
    I have 4 trucks using these diffs, might as well buy a couple packs of each. Just dont want to buy the wrong ones.
    9,244
    Pinion is 6mm and one side of diff is 8mm other side is 10mm
    I was surprised I followed everyone else's posts too bought some shims and needed some 8mm shims that I happened to have from my merv
    Two different bearings. 8x16 5118 and 10x15 5119
    May 2009
    Edmonton, Alberta
    3,632
    Right on, pack of 6 8 and 10 coming up.
    3,271
    Here's another one for you to view mate: Calandra and kyosho shims are good. I use both
    http://traxxas.com/forums/showthread...=1#post5334934
    Rock n Rolla !
    May 2009
    Edmonton, Alberta
    3,632
    I placed an order for all 3 sizes 1 pack each of the Calandras from my LHS tonight.
    9
    Thx everybody for ur help..! All the shims are ordered.
