Page 1 of 15 12311 ... LastLast
Results 1 to 40 of 592
    Alberta Canada
    549
    Newbie upgrade, and replacement parts,...
    Just got my pede for more than a month, so still newbie, but as i read in diff threads, i already bought some parts to upgrade and replace those weak parts of pede...
    just want to know from you guys if i got the right parts and upgrade,.... if its not worth it or if it worth
    having it,...
    all from traxxas:
    .....#6852R Driveshafts, rear, steel-spline constant-velocity (compete asse)(2)
    .....#6832X 6061-t6 aluminum caster blocks (blue-anodized)
    .....#6860X Motor mount, 6061-t6 aluminum (blue-anodized)
    .....#6837X 6061-t6 aluminum steering blocks (blue-anodized)
    .....#1952X 6061-t6 aluminum stub axle (blue-anodized)
    .....#3767X aluminum shock caps, 4 (red anodized)
    .....#1747R blue-anodized aluminum 4mm flanged, serrated lock nuts 4
    .....#6893X bearing adapter, 6160-t6 aluminum (blue-anodized)
    .....#6877A clear gear cover
    .....#6836 Bumper, rear/bumper mount, rear (black)
    others:
    .....onyx 5000mah 7.4v 25c
    .....V6AC Balance charger
    .....RPM heavy duty a-arm, rear (black)
    next to buy:
    .....Velineon vxl-3s esc cooling fan
    .....sway bar kit f&r
    .....hard-anodized, taflon-coated t6 aluminum shocks, xlong
    .....led lightbar(chrome,4 clear lights)
    .....6061-t6 aluminum motor plate (blue anodized)
    .....anodized aluminum 17mm hex adapters
    for now im just bashing through snow, havent try bashing at dry land,...
    Glenpool, OK
    14
    IMHO, not sure the driveshafts are needed if you stay on 2S LiPo. As for the motor mount and bearing adapter, check out King Headz. The bearing is larger and lasts longer/works better. I used the Traxxas aluminum parts on my Pede 4x4 and love them.
    USA
    571
    I would get MIP CVD's in the rears if I were you. Expensive, but worth the investment.
    Also, get an "outerwears" shroud. Will definitely help get rid of grass, dirt, small rocks, etc from entering the chassis.
    Alberta Canada
    549
    Quote Originally Posted by pdl2mtl90 View Post
    im planning to have some 3s too,
    and for the kings head? hmmmmm,.....
    ok, il check for it,..... thanks!!!!!
    Quote Originally Posted by stampede_fanatic View Post
    so the #6842R ca$60 is not worth it and i should have the MIP than this? hmmmm,....
    well thanks,......... i will nxt time,....
    and yah. i think i really need the outwears or overtray, cause my pede got snow all over it everytime,....
    Planet Vegeta
    651
    are the new titanium shafts here yet?
    USA
    571
    Quote Originally Posted by janmichael_zamora View Post
    Yes, the MIP CVD's are more worth it.
    The outerwears are a very nice "first" mod to do on your part since your using the stampede on snow a lot. You can also check out the JConcepts "Chassis Over Tray" if you want another alternative besides the outerwears shroud.
    Salisbury, NC
    633
    Oh, the driveshafts are definately needed w/2S LiPo. I kept twisting mine and breaking U-joints on a 4200 NiMh. I've had MIPs on the rear for about 8 months and this weekend the front MIPs will be going in after tearing up one of the Integy XHDs that I had on for about 4 months. Unlike MIP, you can't repair those when they break.
    Pueblo, Colorado
    53
    Lightbulb
    having it,...
    all from traxxas:
    others:
    next to buy:
    There are a couple of parts that I have broken during my first few runs:
    1st mishap: Stub Axle Carriers (Front)
    2nd mishap: Golden Horizons Alum Gearbox (Connects to rear lower control arm)
    Rear Shock Shafts (Don't forget the shock oil)
    Tire glue (Running with LiPo Batteries i.e. Lots of Torque)
    Also these part (Better safe then sorry)
    RPM Gear Cover Black (Prevents dirt from getting into the gears)
    Traxxas Bumper Front Slash TRA5835 (Much better bumper protection for your Stampede)
    I have a Stampede VXL
    MrTLV
    Alberta Canada
    549
    thanks for all of you guys,
    overtray,
    mip shafts,
    kingshead,
    some questions again,...
    can i use the rear driveshafts in front?
    also the a-arm rear? can i use it in the front?
    will it fit?
    Sep 2010
    middle o nowhere Ill-inois
    784
    Front and rear arms are the same. For the MIPs you do need a designated front and rear though due to different lengths.
    Summit, ERBE X2, 4pdes, 2pdes, etc lol
    Alberta Canada
    549
    all from traxxas:
    .....#6852R Steel Constant Velocity Shafts, Rear
    .....#3340 Velineon Cooling fan VXL-3S ESC
    .....#6898 Sway Bar Kit, Front & Rear
    .....#6727 Batte
