Results 1 to 14 of 14
    10
    Bad Order -5409 - Please Help!!!
    Hi,
    Sorry for brining this up again – but I have the same problem I have got the 5409 engine and the shaft need to be modify – I don’t want to open the engine and replace the shaft.
    Installing the nut adapter #4844 will surely solve my problem? dont want to replace the shaf.
    Thanks’
    Oren.
    Cocoa Florida
    4,808
    Quote Originally Posted by oreno View Post
    Hi,
    Installing the nut adapter #4844 will surely solve my problem? I don't want to replace the shaft.
    Thanks’
    Oren.
    Yes the TRX #4844 is what you need for the #5409 multi~shaft engine.
    Look out for the tree/crunch!
    LiPo? Naw NITRO!!
    10
    Thanks man!
    Woodward, OK
    694
    So if you use the #4844, does your flywheel attach to that, and then your clutch, and clutch bell? Are there other parts you need to use that engine and part# 4844?
    Cocoa Florida
    4,808
    The #4844 is the flywheel nut & what the CB bearings spin on with the Multi shaft engine.
    The above engine uses the crankshaft pictured below, which requires the use of #4844 nut w/pilot shaft.
    LiPo? Naw NITRO!!
    Woodward, OK
    694
    So do you just use the clutch bell? does the screw hold the clutch bell on? do you not run a flywheel if you run the adapter?
    Cocoa Florida
    4,808
    Quote Originally Posted by westoakmech View Post
    You always need the flywheel.
    The screw & washer keep the CB on instead of an E~clip.
    The #4844 is just the flywheel nut & pilot shaft in one.
    LiPo? Naw NITRO!!
    Woodward, OK
    694
    Ok I see now the nut holds the flywheel on the crankshaft. I was just not seeing that part. Thanks wildman
    Cocoa Florida
    4,808
    First time I saw one in person it I thought the crankshaft was broken!
    LiPo? Naw NITRO!!
    Woodward, OK
    694
    Yeah my buddy ordered the wrong engine, and we were gonna try to make it work. Thanks again
    10
    I ordered that part and wating for it.... but I cant see the screw on the Traxxas #4844 that I ordered, what is the screw for?
    10
    wanted to say one more thing - the 4844 is 3*10mm and the 5409 is 5*15, how the 3mm is going to fit the 5mm?
    thanks,
    Oren.
    Cocoa Florida
    4,808
    The 3mm goes into the CB end to hold the CB in place as there is no grove for an E~clip like on the ISP engine.
    LiPo? Naw NITRO!!
    10
    WildMan Many thanks for you answers!
    Traxxas should be Grateful for the support we all get from ppl at the forum.
