Results 1 to 19 of 19
    33
    Will Hyperion 1600mAh 3s EX 45/90C batteries fit e-revo 1/16
    http://www.amazon.com/dp/B003YI5CSA/...A&linkCode=asn
    Will this fit? It can deliver 72 amp continious, could be the ****!
    Rotterdam, Netherlands
    8,279
    Quote Originally Posted by Pirathore View Post
    Will this fit? It can deliver 72 amp continious, could be the bomb!
    It looks like those are too thick. They are a little expensive imo
    33
    Yeah i am afraid they are too thick :/
    anyways...
    http://www.maxamps.com/Lipo-1850-111-ERevo-Pair.htm
    Does these deliver half of what they claim? Because if they do, they should do the trick!
    Alma, Michigan
    12,314
    I watched a comparison video a while back on MaxPrice er Amps batteries.
    They performed no better than a $8 pack. As a matter of fact, the $8 pack ran longer and it was rated for less mAh.
    Unfortunately, there is no industry standard as to how to rate the discharge rate of packs. MaxAmps takes full advantage of this fact... the pack may be capable of 100C, but I imagine it is only for a split fraction of a second burst; no where near constant.
    SPC, on the other hand, honestly rates their packs... as does Traxxas and a few others. I would stick with the honest sellers/manufacturers/distributors over how MaxAmps operates.
    Pittsburgh
    808
    Everything I have seen from any source but maxx amps agrees with the above post.
    0111001101101001011001110000110100001010
    Hong Kong
    67
    I have the 35C version, and it is far too thick to fit in MERV battery compartment. But 45C 1100mAH fits. This brand battery is very punch, but almost all the LIPO I have puffed after a few runs.
    Alma, Michigan
    12,314
    Quote Originally Posted by Supernova View Post
    Sounds like you are abusing your packs!
    Properly used LiPo's do not puff...
    33
    Then the question is...
    What is the ultimate 1/16 traxxas lipo battery?
    We should start a sticky thread or something so all new owners can get the best recommendations!
    And again... What is the ultimate lipo for 1/16 traxxas
    8,279
    There is no single ultimate battery. Simply because some use 2S and some 3S while others use both.
    Anothing thing is that you need to know what is the most important aspect (which is not the same for everyone) like driving time, max amperage, price, etc.
    For 2S my choice is simple: SPC. I never found any better battery for that price. That price factor sadly doesn't count from a Dutch point of view, but that is not SPC's fault, but due to the idiot shipping costs.
    33
    Yes there is. I understand your points. But.
    What is the best performing 3s battery for e-revo. Which can give the most amps? and combined with highest capacity preferably 1800mah +/- which battery fits that has the most punch and amps?
    I have ordered a previous version from this guy (the ones i bought was 45c)
    Now there is a new version, i think that might be the best traxxas 1/16 battery available.
    http://www.ebay.com/itm/TRAXXAS-1-16...item2c66402472
    33
    And then they was bought... Will give you a update regarding wheter they met my expectations or not...
    16
    If I understood the article I was reading last night, a car will have a certain maximum full power draw and any battery that the C rating exceeds that draw is overkill. I assume there are lots of factors involved including gearing, after market motors, esc, servo, etc? So how would one go about determining what the max C rating battery needed to give the car everything it can do? Or do I misunderstand and a car will draw however much C is available?
    Alma, Michigan
    12,314
    Any RC will only draw the amperage it needs... no more.
    Giving a target C rate is misleading... available amperage depends on at least two factors, not one.
    33
    Overkill is better than underkill/puffed/burned to the ground.
    I want to know which battery can deliver the most amps on 3s that fit inside the compartment.
    I am going to install 6s (2x 3s paralell) in my e-revo and use big block motor so i need something with much power as possible.
    so cal
    9,244
    You would need something to measure it. I have a Watt's up meter and an eagle tree e logger. It shows amps watts voltage drop etc...
    With taller gearing or bigger taller tires you will put more load on your system drawing more power same driving through tall grass
    Alma, Michigan
    12,314
    Two 3S in parallel is still 3S.
    33
    oops my bad typo, of course i meant 2x 3s in series for 6s power, thanks for correction
    so cal
    9,244
    My strongest is between thunder power 65c g6 and boost 3s
    Definitely not cheap! http://www.ebay.com/itm/140850084554...84.m1439.l2649
    Wont even be able to use more than 4s unless you have a low kv motor
    Hong Kong
    67
    Actually I am using 3S 45C 1100mAH pack for my 1/16 summit with Hobbywing 70A stock motor. It puffed in the 2nd runs. I have another truck using Hobbywing 60A with 380vxl motor running Hyperion 35C 1600mAH 3S LIPO. Puffed a bit ...... I have other brand LIPO like Max Amp and ip LIPO. None of them puffed. I have asked this question to LHS guy, and surprisingly, the guy told me that it is normal. So I am fading out my Hyperion LIPO and switch to other brands. Personally I do not recommend Hyperion LIPO.
