Page 4 of 5 FirstFirst ... 2345 LastLast
Results 121 to 160 of 182
Thread: Revoman's merv
  1. #121
    Yakima, Washington
    1,440
    well i have ran my car for about two months now without shimmed diffs and have had no problems. Is'nt the problem if your diff is a little loose in the bulkhead, because when i took my diffs apart to put oil in them and then put them back in the bulkhead they we really firm in their with absolutley no movement do i still need to shim the diffs?
  2. #122
    Yakima, Washington
    1,440
    is it ok to have no shims
  3. #123
    Toronto
    414
    It's ok without the shim if you don't hammer the throttle down
    If you get it goin slowy Then hammer, it'll last a bit longer.
    Every bulkhead is different
    I got a few nip bulkheads n some from the bay. What I did was see which halves had the best fitment between them and used those before I even shimmed
  4. #124
    Yakima, Washington
    1,440
    i have had my car for two months with no probs
  5. #125
    Toronto
    414
    You won't notice any stripping from the ring or pinion until it gets to the point you have less punch(contact area of ring/pinion) and loose some teeths. You'll know when it's slipping/skipping
    2s or stock pack will be the best bet in getting the most out of the diff
    It comes down to how you drive also.
  6. #126
    Yakima, Washington
    1,440
    i do not drive 3s and i try to drive carefully
  7. #127
    Yakima, Washington
    1,440
    So i just ordered me a hitec metal geared servo can not wait for that to come. I really want to get the hot racing shock bodies but i can not find them anywhere. Does anybody know where I can get some.
  8. #128
    9,244
  9. #129
    Yakima, Washington
    1,440
    I want black but the blue will work
    thanks for the info 50togo
  10. #130
    Yakima, Washington
    1,440
    so I got my servo today
    it is a Hitec HS-85mg, and i got it on amazon for $23
    here it is compared to stock
    looks pretty sturdy on the inside it also has a bearing around the final gear
    I used one of the attachments that was in the bag it came with to make the connection
    all mounted up
  11. #131
    9,244
    I would make a longer link between the horn and the servo saver. The shaft on the stock servo is closer to the center then the hitec
    Use two 7059 rod ends and cut a 3mm bolt for the stud
  12. #132
    Yakima, Washington
    1,440
    ok i will try that
  13. #133
    Yakima, Washington
    1,440
    ok just finished dying all the grey parts black i will post up some pics of it all together
  14. #134
    Yakima, Washington
    1,440
    as of now my diffs are shimmed
  15. #135
    Gold Coast, Australia
    392
    Quote Originally Posted by revoman78 View Post
    No !
    Rip the diffs apart and shim them properly.
    When you use 3s lipos you'll realise why
  16. #136
    228
    Looks very well.
    All these dying projects make me thinking about dying my one as well :-)
    Edit: Shimm your diffs, it doesnt cost that much and if the diffs get stripped it will be to late to shimm.
    I make this mistake as well. Everything was okay for nearly half a year and than the diff begins crying if there was a little load on it. I try to shimm it than, but no chance, it was okay for 2 or 3 runs and than it crys again.
    Think of buying the Losi Crawler Horn it is the best combination for the hitec.
    With the stock ones I didnt get the wheels "centered" there was always one site with a smaller cornering radius.
  17. #137
    Yakima, Washington
    1,440
    if you read the post above your guys it says i just shimmed the diffs, i knew they needed to get shimmed but i was to lazy to take it apart, but since i died it it was already taken apart so i stuck the shims in.
    i like my car to be colored cordinated i so not see why traxxas does red shocks and pushrods with a blue servo, motor, and esc, now it will all be black and blue
  18. #138
    Yakima, Washington
    1,440
    ok finally got the servo thing sorted out not as clean as 50 togo's but it works well
  19. #139
    Poconos
    304
    In my opinion its not about the "show" it is about the "go"
    If it works that is all that should matter!!
  20. #140
    Yakima, Washington
    1,440
    I have been having problems with the range on my car, i get about 25 feet and then it cuts off. I have no idea as to why.
  21. #141
    12,318
    Antenna damage is the main cause of poor range... either on the receiver or the controller.
  22. #142
    Yakima, Washington
    1,440
    how is it fixed i think the antenna on my receiver is damaged you can see the antenna on the pics above
  23. #143
    12,318
    I see antenna tube, but no antenna.
    Usually the only way to fix the Rx antenna is to have it replaced... $15ish with the Traxxas lifetime warranty program.
    I have read of some fixing their issues by modifying their antenna... cutting it back so only 3.25??cm of the center wire sticks out. That is the only part that actually receives the signal... the rest is just an extension.
    Keep in mind that these antennas on the 2.4's are coaxial.
  24. #144
    Yakima, Washington
    1,440
    can you explain coaxial?
  25. #145
    12,318
  26. #146
    Yakima, Washington
    1,440
    thanks, so there might be a chance of saving it if i can get the middle wire out be itself.
  27. #147
    12,318
    Yes. Make sure the jacket and outer layer is in tact all the way to the Rx... and the length that needs to be exposed is critical. I suggest PMing Krall... I think it was he that posted that length.
  28. #148
    Yakima, Washington
    1,440
    so this is what the antenna looks like it is sheared off until where the metal ends
  29. #149
    12,318
    That would be why range is suffering... lol
  30. #150
    Yakima, Washington
    1,440
    do you think it is still salvageable?
  31. #151
    12,318
    Post 147.....
  32. #152
    RC Champion dcfox's Avatar
    SE Texas
    1,198
    The main thing for reception is to make sure that none of the shield(copper mesh) is touching the main conductor.
    Even one strand can all but kill reception.
    "Dude,I almost had you"
    R.I.P Paul Walker
  33. #153
    Yakima, Washington
    1,440
    i got it to the receiver working again, I did not think it would work, all i did was strip some of the rubber off the wire.
  34. #154
    Yakima, Washington
    1,440
    I went out on the road today just wanted to share some pictures
  35. #155
    Apr 2013
    368
    looks good revo man! Im really enjoying the e revo you sold me! Gets alot of use around here
  36. #156
    Yakima, Washington
    1,440
    thanks man!
  37. #157
    Yakima, Washington
    1,440
    Does anybody know when the new proline mini trenchers will be out, they look pretty awesome
  38. #158
    204
    from what i have seen they wont be out for a while
  39. #159
    Yakima, Washington
    1,440
    I have a feeling they are going to sell really well.
  40. #160
    Yakima, Washington
    1,440
    So I decided to put $20 in my merv budget what should i get.
