Thread: Glow Plug
    New Jersey
    50
    Glow Plug
    What is the best glow plug for a Jato? Also, if you are fouling plugs fairly quick what could be the problem? Anyone have a good setting for all three needles to start with? I am running that Backyard Basher Fuel
    Thanks
    Jul 2011
    S. Jersey
    773
    I use O.S LC3 or LC4 plugs. If you're fouling plugs quick i would take apart the engine and check for debris and clean everthing out. If that's not an issue it might be your tune. Colder weather=richer tune. I never ran that fuel so i can't give you a good starting point. Just set it back to stock and go from there. Where in Jersey are you?
    Jato 3.3, Revo .28 JL Max, Nitro Stampede 3.3
    New Jersey
    50
    Central Jersey Bridgewater Area. My brother, nephew and I all have Jatos that we bash around with. I buy most of my parts from Hillsborough Hobbies. I have the stock Traxxas plugs and some LC3 plugs, i never had this issue prior to switching fuel so maybe like you said I just need to return it to stock and start from there, is there a way to clean out the engine without taking it apart?
    Jul 2011
    S. Jersey
    773
    You can take off the the cooling head and take a look at that the piston.
    Wake Forest, NC
    406
    I very rarely foul a plug when it is tuned properly. Too lean = fouled plug and bured up motor. Too rich = fouled plug (albeit much longer) and longevity on motor. Run 30% or higher nitro will = cooler engine temps and better performance overall. I wouldn't skimp on fuel quality. A new motor is more expensive in the long run.
    Nitro-J-Rod
