Results 1 to 4 of 4
    LED flashes red-green; 2080 servo replacement
    Hi,
    I have the 7105.
    I have had to replace the 2080 servo as mine burned/melted/fried.
    After replacing with new servo, the LED on the main unit (ESC?) goes into a flashing red to green to red...mode.
    Once in that mode, I can't even use the button to turn off the unit.
    What does that flashing mode mean?
    Ideas?
    Mark
    9,244
    Don't know why nobody has helped by now.
    Disconnect the servo and see if it still blinks. If it does the old servo burnt the esc too
    29
    the ESC may be in lipo mode. If you are using NiMH batteries, the esc sees too much voltage and flashes red/green. Switch back to NiMH mode by holding the set button for 10s. Should beep 3 times and switch modes. Maybe.
    3
    As Apaulo13 said.
    check this out from when I was having similar problem.
    http://traxxas.com/forums/showthread...flashing..HELP
