Results 1 to 12 of 12
    Oct 2012
    23
    Engine will rev but will barely move
    I've had all kinds of issues with this truck......
    I rebuilt the transmission, replaced all the gears inside and put it back together. I'm wondering if I did something wrong.
    Started right up and when I gave it gas it revved really high but barely moved. Now it will just rev really high but won't go anywhere.
    Don't know if this has anything to do with it but I don't remember the truck being able to roll freely forward and backwards if you push it but mine is now, is that normal? There is no resistance it will just roll like a toy truck (if that makes sense).
    Any suggestions?
    Oct 2012
    north east iowa
    149
    Your slipper too loose?
    Sep 2012
    Kentucky
    101
    I say the spring for the clutch shoe is broken, take the clutch bell off an see
    Riverton Utah
    5,384
    I'd check both, it's normally caused by either one.
    The Wolf is not concerned for the sheep's opinion
    Oct 2012
    23
    I'll check both of them. Thank you everybody!
    392
    also when you had the transmission out on the primary shaft there is a c clip looking piece that holds a pin in the shaft mine broke on me and it "rolled like a toy truck" just a thought ill post pictures if you dont know what im talkin about i dont think it would be you clutch spring what ive noticed with that is it would be always in motion and never stop and if it did it would killl the motor but check that pin inside
    drive it like you stole it
    Mar 2009
    1,973
    if you can roll the truck in both directions without resistance. they are a couple of scenarios
    1/ you said you pull the trans mission out. check to see if you left out a pin on one of the shafts, either the 2 speed shaft or the output shaft...
    2/ did you reconnect the driveshafts? i doubt you will forget that.. just thought i'd ask..
    3/ do you have reverse in your truck?? if yes maybe you installed the reverse gears wrong or left something out
    you know.. i never had a sig.. but i do now...
    Aug 2012
    Sydney, Australia
    21
    Check your one way bearing
    T Maxx RB TM523, Revo OS 21tm
    Palisade Colorado
    510
    Quote Originally Posted by RevoMatic View Post
    Are you talking about the easy start?? I'm not hating but I'm not sure it has to do with this problem but I might be wrong????
    392
    uphoto did you ever figure out what was wrong
    Norfolk, va
    1,164
    Quote Originally Posted by johnzillia54 View Post
    There is a one way bearing on the first gear gear.
    ERBE, ERBE, Summit, Slash 4X4, Bandit,
    Palisade Colorado
    510
    Ohh ok that one that makes sense now lol sorry I forgot about that one lol sorry man
