Thread: glitchy?
    harrodsburg ky
    445
    glitchy?
    So I'm outside the summit vxl hasn't been run in maybe a month and I take it out at 3am for a wet run and to start of it didn't respond at all then it kicks in and runs then glitches and shuts off then I turn it on again same thing runs then glitches then off. I know this isn't normal even if it's 30F outside it should run even better! What's wrong is the ESC dead? Or dying?
    Oct 2012
    cincinnati oh
    110
    Wake me up at 3am and with the weather u described and i would do more then glitch.
    R u running lipos? Look for oxidation loose connections give us more information and maybe we can help
    If all else fails call the man....
    Alma, Michigan
    12,318
    Check the Rx box for water...
    While you are in there unplug your servo and see if the issues clear up.
    Oct 2012
    cincinnati oh
    110
    [QUOTE=Jimmie Neutron;5356130]Check the Rx box for water...
    Sounds like it happened before it got wet after it sat for a month. And if it was run hard and put away wet aa month ago
    Well nuff said
    Then.
    harrodsburg ky
    445
    Yea happened while I was getting ready to go outside I had it on and running before heading out but then it done it's thing of messing up on me and all the seals are new I just reason why it hadn't been run is cause I was slowly replacing the seals and bits of the drive shafts but yes I'll try it anyway
