Thread: which one
    Lincolnshire Il
    37
    Question which one
    i have a 1/16 summit and i need electronics, its a roller right now, can i use the 1/16 5200kv motor and 25amp esc from ezrun hobbywing brushless with the regular motor mount or would it need some modding? PLease let me know if this would fit in the 1/16 traxxas summit!
    12,314
    Can we have a link?
    or at least a part number?
    I am pretty sure that 25amps will not be enough to push around a 16th though...
    Lincolnshire Il
    37
    Sorry, heres a link of the 35 amp esc and the motor http://www.nitrorcx.com/96m01-car-2030-7800.html and http://www.nitrorcx.com/hobbywing-ez...-1-18-car.html and http://www.nitrorcx.com/hobbywing-ez...-1-10-car.html Jimmy neutron.... Thanks for all your help. Have you had any problems with over heating or anything? Is it worth getting that over these things?
    Traxxas has a strict language policy. A word filter operates to change banned websites or brands and inappropriate words to *s. When you see these in your post, you MUST edit them out.
    -ksb51rl
    12,314
    This motor has a very high Kv rating... I do not have experience with high Kv; I suggest either waiting for 50togo to chime in or send him a PM. I am sure he will be glad to help on that.
    Notice how this ESC is for 1/18th? You never want to go smaller with an ESC... especially when a 16th scale is boarder line with these RC's.
    This might be ok... but I would rather see something with a higher rating.
    I am geared 23/50 most of the time with buggy rear hawgs. I really do not need to worry about heat unless the ambient temps are 90F or above when I am running 2S... I also tend to stay off from grass. I have ran a few speed passes geared 28/45 on 3S... that created some heat! But that gearing is also only for a huge open area since it is good for 60-65mph.
    392
    it depends what he runs, if he runs 3s, you'll need lower amps than 2s. but at any rate, after the nonsense I went through with my LST2 conversion, I would just stick with the factory powertrain. why make trouble for yourself?
