Results 1 to 12 of 12
    135
    CC Blower, not working
    Just added the CC Blower fan, but it's not working. Is it supposed to run all the time? Plugged in to chanel 5/batt.
    Frisco, TX
    388
    Yeah it's supposed to run all the time. Is it new? Did you try switching the way it's plugged in?
    kansas
    8,651
    the brown or darkest wire should go to the outer edge of the Rx...
    Apr 2009
    380
    Sounds like you have it plugged in backwards. The Black wire should be on the outer edge of the receiver and the open pin goes inwards.
    135
    I have to check, did not think it fitted both ways. Thanks
    9,244
    Always possible that its defective
    Kentucky
    101
    Do they take any noticeable run time away?
    Central NJ
    1,245
    No, they dont have an effect on run time. The current draw on those is so miniscule you could run the fan probably for a week or more on the battery.
    Norway
    290
    Which blower are you using? I see there are 3 different models on AMain: CSE011-0004-00, CSE011-0014-00 and CSE011-0019-00.
    kansas
    8,651
    Guess I will ask why do you need the fan?? Is the motor running that hot you need a fan??
    A temp gun is kind of a must have.....
    Everything warm just right..
    Motor ~ 180/190*F (82/88*C) maximum, ideally 140/160*F (60/71*C), temps can be 10*F higher inside the motor
    ESC ~ pretty much same temps / Fan comes on @ 150*F (65*C)
    Lipo's ~ 140*F (60*C) max, ideally 100/120*F (38/49*C).........
    Besure to check sizing before you buy any batteries...
    Frisco, TX
    388
    87 GN-
    Everytime the CC blower fan comes up, you post the same thing. It makes me laugh every time!
    Although I agree that proper gearing is the key to manageable temps, I still run a fan on my motor. I guess it's just the peace of mind I get knowing my motor's gonna run 10* cooler! Haha. The hottest I've ever seen my motor is 137* after lots of speed running and hard bashing on 6s w/ 40 series trenchers. So really, the fan is just taking up space.
    135
    why i need the fan? well, don't need it but i like the way my e-revo is geared rigth now (18/58) but motor gets a bit hotter than i like it to sometimes. Everything warm as you say is good but cooler is even better.
