    Des Moines Iowa
    35
    $6 drifting tires (tires???)
    So i bought these at a local store that Paul Menard drives for in nascar not sure if i can use the name of the store that MENARD drives for ;-) . So i found these and they looked better than the regular white pvc pipe and the 2" white pvc doesnt exactly fit these rims. They come in gray and here is the label.
    and look like this. I used a dremel with a cut off wheel to take off the outside lip. Then used a sander to clean up the cut side. I used hot glue on the inside and made a full run. It is a blast to drift and i feel its a good way to practice drifting as a newby. Here is the car with them on after one run. nice thing is when or if they wear out they can easily by switched out. I did have one wheel come loose my fault just threw them on and went for it. I will dye them black and shape the edges to simulate a tire better, and hot glue them on better.
    Yakima, Washington
    1,440
    that is very creative good job
    Des Moines Iowa
    35
    Next step i decided to carefully grind with a dremel the edge of the tire to give it a little shape. Im thinking about dying them black but not sure the hot glue holds the drift tire on very well and makes removing them easy.
    May 2009
    Edmonton, Alberta
    3,633
    Ingenuity is awesome! I like it. Like those HPI rims too
    36
    Rubber vs. pvc
    The Mitten
    1,685
    Quote Originally Posted by Gymkhana1999 View Post
    Rubber vs. pvc
    You dont necessarily need PVC.
    Lots of drift tires are ABS plastic or Molded ABS
    Everything overpowered...
