Results 1 to 8 of 8
Thread: is it safe
    Yakima, Washington
    1,440
    is it safe
    I was playing around with my brothers mini summit and we had a lipo battery for a rc airplane that i hooked up but i want to know if i will reck with it the car because it is 11.1v 3s battery with 15c continuous discharge with 20c bursts. very small battery 1300mah
    Oklahoma City, OK
    2,665
    in theory......that sounds like it will work just fine. wont last too long - 20 minutes maybe
    Enter at own risk - it it were mine, I would try it.
    "RED"
    Yakima, Washington
    1,440
    ok i just have never worked with lipos and did not know, but thanks for the info
    Tazewell Va. Were so small here in taz. that we only have 3 stop lights....and one is broke
    169
    you could even run a much higher discharge rate, but the summit is a little hard to control on 3s.
    Toronto
    414
    Make sure the esc is in lipo mode. GREEN light for lipo
    12,315
    If it is a brushless RC; Yes, you can use that battery.
    If it is a brushed RC; NO, you cannot use 3S LiPo... 2S MAX!!
    Pittsburgh, PA
    662
    If you do use it be careful. With that low of a discharge rate you may "puff" the lipo with to many continuous speed runs.
    12
    It should work
