Results 1 to 10 of 10
    friendswood texas
    1,700
    soldering help PLEASE
    I have to solder the battery connection on. I have a GOOD iron and have done it before. After some youtube research I think I am doing it wrong. I don't want to turn a simple job into a nitemare.
    traxxas emaxx
    Guest
    Have you tried to solder it yet
    Davenport, Iowa Quad Cities
    2,471
    Any pics of your situation?
    friendswood texas
    1,700
    No I have not tried yet Just looking for input to not do it wrong. need to solder male traxxas connector and just want to get it right the first time with no problems.
    2,471
    I use a piece of foil over the end I don't want soldered.
    Feb 2010
    11,772
    I put tape over the wire not being soldered. Then be sure to insert the soldered wire into the proper side of the connector housing to make sure the wires don't touch. You can do it!
    Spirit Lake, Iowa
    76
    What I do is just cut one wire at a time. Cut the negative side off, solder the tab on, stick it in the Traxxas connector, then do the other wire. That will keep your wires from touching and shorting out the battery.
    Central NJ
    1,245
    OP said he was soldering a male connector, hopefully not on a battery!
    Good hot iron, lead fre silver solder. Tin the wire first then put the iron about halfway between the end and the mark for no solder and heat up the connector and touch the solder to it until it tins the connector. Ease the tinned wire in there and slide the iron back holding it at a 45 so it contacts the connector and the wire. Takes me like 30 seconds per connection. With solder less is more, dont go by the bigger the bolb the better the job standard. If you cant get it to heat up enough to melt the solder and tin the connector in a few seconds your iron is not hot enough and you will end up with a cold solder joint. Way to tell is if its not shiny when you are done its a cold joint and will break.
    friendswood texas
    1,700
    Quote Originally Posted by JustinThyme View Post
    thank you for the info.
    Spirit Lake, Iowa
    76
    I use a Snap-On portable butane soldering iron. Same model as the one I use on the job, soldering wires on real cars. The one I use on RC wiring is actually my dad's since mine's at work and his is here at home. Gets good and hot, good and quick.
