Results 1 to 10 of 10
    4
    What slipper clutch to use
    Went on website and saw a few rebuild kits for slash slipper clutch then a slipper clutch assembly that looked completely different, can some please provide me a part number for best one to use
    Rotterdam, Netherlands
    8,238
    Many use the Revo slipper clutch. That one has larger alu pads.
    7,176
    I use the ERevo Slipper Clutch. Some think its worth it and others see no need. I'm a fan of it.
    5351 Slipper Plate & Hub Alloy
    5352R Slipper Clutch Kit w/ Alloy Pads
    or
    5352X Slipper Clutch Kit w/ Graphite Pads
    Hope this helps ya bud.
    Weak Revenge
    Strong Forgive
    Intelligent Ignore
    4
    so if I get 5352x or 5352r I also need 5351?
    8,238
    Quote Originally Posted by dmagic View Post
    Yup. I would get 5352R and 5351.
    7,176
    Yessir. Showed you both sets of pads for an FYI.
    When you install this you will move the pin down the input shaft to the next slot. The Slash 4x4, Stampede 4x4, & Rally 4WD were setup for this upgrade.
    Weak Revenge
    Strong Forgive
    Intelligent Ignore
    11,285
    Whats different about this slipper VS the stock slipper? Looks like the pads and disc are the same?
    North Central OH
    1,050
    While on the subject, anyone used the carbon graphite pads from Hot Racing?
    7,176
    It's the one that is used on the ERBE. The 5352R has alloy pads and Maxx spring. It actually has a little wider bite, the shoes might be bigger to, I can't remember. I've upgraded all my 4x4's to it. I feel its worth it as an upgrade.
    Do you have one from any of your ERBE builds?
    Sent from my Samsung Galaxy S III ~ using Xparent Green Tapatalk 2
    Weak Revenge
    Strong Forgive
    Intelligent Ignore
    Marshal Dadx2mj's Avatar
    Aug 2007
    So Cal
    21,511
    On my Stampede 4x4 I bought the 5352R kit and only used the aluminum pads with the stock set up. I really like the feeling just the pads gave the clutch, felt much more predictable and consistent from start of run to the end of run.
    BlindMan Racing
    Rusty - MERV - Pede 4x4-Alias
    SPC Lipo Power
