Page 2 of 2 FirstFirst 12
Results 41 to 79 of 79
Thread: xo-1 upgrade
  1. #41
    wyoming
    594
    found a new set of diffs i am going to try to swing for, they are the supermaxx housings with all robinson racing gears
    and if i cant get the diffs to fit, then i will put 'em in my emaxx lol
    kawasaki summit, revo& slash; regular rusty, pede
  2. #42
    wyoming
    594
    does anyone know of any company that makes metal gears for the e revo transmission? thanks for your time
  3. #43
    Detroit, MI
    416
    Hey Kenny I can't believe I just found out about the thread, shame on you Kenny lol, ok I can tell you a metal spur is not
    Needed, diff are fine just build them right and put read automotive high temp axle grease in there, put it in the diffs
    and the case , forget oil, put glue on the screws that
    Hold the differentials housing on because if you use oil the glue won't work. I have had a lot fail on me and its because those 4
    Screws come lose on the gear where the diffs are. The glue will prevent that . Traxxas bearing burn up with the xo-1 motor so
    Use boca bearings , 2 bucks a piece and you good. Call me or text me and I can explain it better. Good luck Kenny . Btw the
    Stocks shafts will hold up unless you just smash it which I don't thinks you should do lol, it's all in the driving.. Remember
    Metal is expensive to replace plastic is not so just adjust that slipper right and you all good. Just a few minor things no need
    To spend a bunch of money..
  4. #44
    wyoming
    594
    thanks man, i think i will get the center diff, and just not do any diff mods other than those mentioned by kitchen
  5. #45
    wyoming
    594
    batteries and motor mount arrived; can't start the build just yet, as family is here on vacation due to the hollidays
  6. #46
    wyoming
    594
    4 wheel drive steering!!!!
    just kidding... broke a knuckle
    its not what ya think either, i hit a bump, and it cart wheeled; it just so happens to be that the wheel smacked perfectly on a giant slab of concrete...
  7. #47
    wyoming
    594
    about a week ago i got a replacement axle carrier, reinstalled it; found that i had a cracked bearing, and about 5 hours ago i installed a brand new bearing- so it is up and running again! after i get the time to go to our "local" hoby shop i will buy the right gearing and throw in that motor and esc combo! by the way, our hobby shop is 100 miles away...
  8. #48
    Palisade Colorado
    510
    Nice job man I can't wait to see this thing!!! Post up a lot of pics and you should post up a video when your done
  9. #49
    wyoming
    594
    this thread would be useless without pictures and videos of the ending result!
  10. #50
    wyoming
    594
    after learning that the 2200 mamba and the 1717 mamba motors have the same sized shaft, i will hopefully have time in the near future to put the mamba 1717 system in; as i am short of time due to a hour long bus ride to and from school, with a 3 hour wresting practice after school as well.
  11. #51
    kansas
    8,574
    the 1717 I had, was a 6mm shaft...idb..
    http://traxxas.com/forums/showthread...=1#post4915616
  12. #52
    wyoming
    594
    when i go to put on the pinion, i will be looking for any slop whatsoever, if none is found, i will run it.
  13. #53
    TJHSST, NO VA
    1,054
    I used the pinion from the 2200kv on the 1717 so it should work
    sppppaaaaaaaaaaaaaaaaaaaaaccccccccceeeeeeeeee!!!!!
  14. #54
    wyoming
    594
    thats what i heard, thank ya kind sir
  15. #55
    wyoming
    594
    got some work done today, i got the 2200kv motor and mmm esc taken off, while they were off i gave the chassis a good cleaning. I got the custom motor mount situated onto the motor, i am in the midst of taking off the shock brace, so i took off the rear skid plate, undid all the bolts on the center, and went on to the front only to find a stripped bolt; so i am putting off the build till tomorrow to go find the reverse drill bits out of the work truck. thats all that i have gotten done today.
  16. #56
    9,244
    Bummer! I keep a set in my bag but haven't needed them
  17. #57
    wyoming
    594
    i have an extra esc mount screw, im hoping that it will be long enough to replace the stripped one, if not i will just get a regular drill bit and put it right back in lol
  18. #58
    wyoming
    594
    finished it all up, i dont have a camera to upload pics, but i can text someone pictures and they could upload them if they were willing to.
    I took off the shock brace, and made my own little spacers for the top and underneat the shocks where the screw goes, so the shocks wont hit the chassis.
    Everything is really tight in there.
    EDIT: almost forgot, do i need to calibrate the esc to the receiver?
  19. #59
    wyoming
    594
    got the answer- thank you 50
    progress report: i ordered some gearing from the hobby shop- going to run it tomorrow (with stock gearing)
  20. #60
    9,244
    That's good! Always glad to help
  21. #61
    wyoming
    594
    took my first test run today, i couldn't make out any difference out due to the snow making it just spin out (due to the insane amount of torque), but the thing was still hauling with the stock gearing
  22. #62
    9,244
    Little hard testing it spinning those wheels!
  23. #63
    wyoming
    594
    i actually never went full throttle, even lugging arround it was peeling out hehehehe...
  24. #64
    wyoming
    594
    i was messing arround with it today on the highway, i see a car coming and pull off the road, as the car goes by i think "i think i could race him". i pull back onto the road and pass him completely- even with stock gearing i was doing pretty good, arround 40mph or so
  25. #65
    9,244
    That's fun! Probably trips them out to see it accelerate so fast and pass them!
  26. #66
    wyoming
    594
    i think it did... they swerved slightly to the right
  27. #67
    9,244
    I saw a video like that except the rc pulled to the left and the car ran over it!
  28. #68
    wyoming
    594
    i was pretty far on the left lane, pretty close to going off the road actually, i knew the person driving wasn't going to run it over, she was and elderly women and everyone knows they don't do things like that...lol
  29. #69
    9,244
    No the rc driver accidentaly turned under the car!
    Paid the price
  30. #70
    TJHSST, NO VA
    1,054
    kenny so just wondering, do you notice the car topping out quicker with the new motor?
  31. #71
    wyoming
    594
    with the really crappy gearing, its really hard to tell, it certainly gets up to speed quicker, but it seems to top out at about the same speed as the regular 2200kv; but i will be able to give out a better answer after i get some decent gearing.
  32. #72
    9,244
    With the more torque it should be able to handle way taller gearing to male up for the kv difference. Although more load more draw
  33. #73
    wyoming
    594
    well, havn't updated this in a bit due to time loss working on my plymouth duster. Anyways, i plan on charging the batterries tomorrow and taking a video, i also installed a 23t pinion.
  34. #74
    Minnesota
    1,306
    the XO1 motor fits right in the erevo right?
    ERBE
    Savage Flux XL
    Trail finder 2
  35. #75
    wyoming
    594
    to use the stock motor mount, you have to drill it out in a spot, and you have to make your own custom shock mounts in the rear, but their is a kit my kershaw designs that is high enough that you dont have to do any other fabrication other than install the new mount- not even to the shocks. but other than those two things, it bolted right up
  36. #76
    la porte
    697
    I can't see why anyone would need more power than the mm and 2200 kv motor it already has more power than the truck can handle. still cool seeing people do it though.
  37. #77
    la porte
    697
    I take what I said back I just read through your thread I see your going for top end speed and more torque so you can gear it to the moon with the bigger can and lower kv with less temp issues
  38. #78
    Minnesota
    1,306
    Ooo, I'd rather not do any modifications. Plus I have no reason to spend money on a new motor when mine is new.
    ERBE
    Savage Flux XL
    Trail finder 2
  39. #79
    wyoming
    594
    i actually recommend to not do the xo-1 conversion, with the 1717 motor, you are limited on quite a few things, for instance: gearing, drive shafts (as the torque would probably rip certain shafts to bits), and the conditions you run in. Where as you can endlessly mod the stock e-revo as far as your wallet will let you, and have a nearly bullet proof rc. The reason i did it is because im pretty lenient, and i got a GREAT deal on the motor and esc combo.
