Results 1 to 14 of 14
    in texas currently
    104
    help with my dodge ram
    has anyone ever changed a heater core on a 02 ram 1500 i got around to checking and its leaking coolant through the vents at the bottom and i was wondering if anyone has a little more insite into this problem or if its just a bad hose or if i actually need to change out my heater core. Im sure im forgetting something so if you have any questions and ill answer them.
    -Cody
    RC Qualifier MooseSlash's Avatar
    Dallas, TX
    803
    I'm sure people have changed the heater... Do you mean the engine block heater and which vents are leaking??
    in texas currently
    104
    Quote Originally Posted by MooseSlash View Post
    the floor vents and not its the heater core inside the cab
    thank you for the info everyone.
    11,547
    Typically the core is copper and aluminum and the pipes stick out of the firewall where the rubber hoses attach to it. If it was the hose then the leak would be in the engine compartment; since it is leaking out inside the vehicle very good chance the core has a hole in it. A temporary fix is you could disconnect the hoses going into core and connect them together but you will not have any heat.
    Feb 2008
    Fl
    3,062
    I believe he means the hvac heater core that heats the interior of the truck. If you are getting coolant into cab area, there are no other culprits. I am sure you can find the procedure on autozone.com or somewhere online.
    here you go!
    https://www.google.com/search?q=02+d...hrome&ie=UTF-8
    Andover, mn
    169
    cody, its not going to be fun in anyway. you will be a contortionist by the time you are done. its gonna take you between 4 -6 hours. just being honest. but you will feel great by the time you are done.
    3908 emaxx, brushed... slash 2wd... whats next?
    in texas currently
    104
    ya but i cant be a contortionist my back doesnt bend like that any more :\ but i think im going to completly pull out the interior dash and everything and spray some rubberized coating on the metal so i guess thatll give me a good reason to do that.
    Oklahoma City, OK
    2,688
    At home depot and lowes they sell thin rubberized flashing in rolls. its about 1/16" thick and has mailable flashing on one side. It is adhesive. It is used for installing metal roofs. Tons of restoration guys use it to line their floorboards and firewalls to reduce road noise, keep heat off their feet from engine and eats road vibrations that travel through your feet. its a lot like dynamat at a fraction of the cost
    I have used it and I love it! Goes on fast and easy! Just unroll, lay out, cut, peel and stick!
    "RED"
    in texas currently
    104
    that sounds like a great idea Red i didnt even think of using that stuff
    Palisade Colorado
    510
    I know how to bit check every were like around the heater core hoses but the last thing you want to do is start throwing money at it
    Guelph Ont Canada
    16
    Ive done a 1998 dodge dakota heater core ..took about 8 hrs for me to do it my suggestion is to buy yourself a Haynes Repair manual .Showes step by step how to do it .
    in texas currently
    104
    Quote Originally Posted by Troy1965 View Post
    i usually use chiltons cause i get em for free on ako
    NB Canada
    22
    Not sure what the 3rd gen Rams are like, but I do know that the 94-01 Rams require removing the dash completely (or almost anyway) to change the heater core, so if you are considering stripping the interior that may be the best time to do the core. Luckily I haven't had to do it on my 98 (yet). Check out Dodgeforum.com for tips, that's the best site I've found for anything you want to know about any dodge. Been a member for years and I've learned a TON about these trucks there. Good luck!
    in texas currently
    104
    ya 3rd gen rams are a nightmare to work on.
