View Poll Results: how do you like my thread
Voters
30. You may not vote on this poll
  • like
    28 93.33%
  • dislike
    2 6.67%
Page 3 of 22 FirstFirst 1234513 ... LastLast
Results 81 to 120 of 841
Thread: Kawasaki e revo
  1. #81
    9,244
    Pulled the front diff apart. Good thing was leaking oil all over!
  2. #82
    4,849
    the diffs look pretty good still, saving them for spares?
    DEU 8:18 ESV
  3. #83
    7,262
    leak...thats what i thought when i first open up mine but turns out to be the grease from the ring gear thin out over time and leak out.
  4. #84
    9,244
    yep spares
    i hope had to reuse the gasket the rrp8090 didn't have one! the other did
    didn't need any shims. started with .2mm in the pinion and .2 one the stock cup .was too tight ,took the pinion shim off ,then tried .1mm with no pinion shim ,then .1 on the pinion and no shim on the cup! then took that one off
  5. #85
    9,244
    wow this is getting expensive ! sold something on ebay and bought some more parts center cvds for the revo and the maxx
  6. #86
    7,262
    yep they are a whole different ball game than the 1/16 but, worth every upgrade in the long run.
  7. #87
    9,244
    Good run time with the spc 5400 50c. Longer than I thought !
    Yep I figure replace before it breaks. Getting hard to get my daughter out riding and every second counts!
  8. #88
    4,849
    runtimes on my lipos only being 4000mah are 30mins+ each time.
    if you have the cash now to upgrade why not i upgraded only because someone broke my upper a arm on my merv so i picked up all the a arms and bumper. upgrades installing them is fun but then i always have to look at it when i am ready to run and say no its looking new again if i run its going to be all messed up again hahaha but part of the hobby that doesnt last i stick the pack in there and run it anyways.
    DEU 8:18 ESV
  9. #89
    9,244
    has anyone had a problem like this! when i assembled the front end when installing the summit axles the left side rubbed against the diff cup. the ring gear side has a bigger hole then the left side and was hitting . i opened it up a bit with the dremal and works fine now
    I was balancing the tires but some needed 12 grams of weight on one tire! need thicker lead tape!
  10. #90
    7,262
    when i had my summit i did'nt see any rubbing issue in that area but, the previous owner use a longer grub screw pin and eat up the plastic around that area.
  11. #91
    9,244
    Found some wheel weights but now they are California safe which means lead free. So hack saw time.
  12. #92
    9,244
    Almost ready rpm carriers due today. Summit axles and stiffer springs installed.
  13. #93
    4,849
    looks good with all that rpm on there. i like the way the summit axles look on there.
    DEU 8:18 ESV
  14. #94
    9,244
    had to order some blue hubs now that blue took over!
  15. #95
    4,849
    have you seen spc has the 6500 50c and 6500 65c lipos both 2s. now today they have 8000 50c now that is a wopper of a battery only 200mah from the last 2s they had but a higher C rating. great prices
    DEU 8:18 ESV
  16. #96
    9,244
    Tires balanced!
    Set the rear camber to neg 1 degree
  17. #97
    9,244
    Another trick I picked up. Thanks again!
  18. #98
    9,244
    i doubt they fit though!
  19. #99
    9,244
    I have it together! I will test it out tomorrow!
  20. #100
    Aug 2010
    Port orange, Florida
    568
    Spc says the new 8000 50c pack fits erevo and summit might have to try out a set for 46 a battery how can you go wrong
    Sent from my iPhone 5
  21. #101
    9,244
    I was thinking the 65c
    I just bought some more 5400's wish I seen those
  22. #102
    4,849
    Get the 8000 or the 50c's are a great deal. Shoot if I could I would get the 8000 for my emaxx though I don't think I would ever run that much mah so maybe the 6500 50c would audit me better and priced good as well.
    DEU 8:18 ESV
  23. #103
    9,244
    Has some new company !
  24. #104
    3,271
    I like the blue theme you got going there mate .
    Rock n Rolla !
  25. #105
    9,244
    thanks should of put the blue mervs in there too!
    tried out the spc 3s 5400 50c today! the acceleration reminds me of one of my mervs on 3 cell!
  26. #106
    4,849
    which did you try the lipos on emaxx or e revo? nice collection you got going on there.
    DEU 8:18 ESV
  27. #107
    9,244
    i ran the 3's in the revo .the e maxx has some play in the rear pinion(pull and push on the rear shaft ) so 2s untill i shim them!
  28. #108
    kansas
    8,239
    A stock E Maxx doesn't hold up well to 2/3s power..........
    Bulks, chassis, & shock towers all need upgrade.....
    The thing is I really like the look of the Maxx, but it just can't take a heavy beating........
  29. #109
    9,244
    i have some aluminum bulkheads and rpm shock towers i could take off my t maxx but i don't really plan on running 3s . i am just going do some shimming ,center cvds and rpm upgrades and that will be my daughters truck
  30. #110
    9,244
    Thinking of one good servo instead of two . Get a decent one or a nice one?
  31. #111
    9,244
    Got some more stuff today!
  32. #112
    9,244
    Looks like I will be pulling those diffs apart again!
    Just ordered Boca yellow seal ceramics for the complete car and orange seal motor bearings for the 1515
  33. #113
    9,244
    i knew the trenchers were big! next to e maxx
    what kind of gearing for these tall tires!
  34. #114
    4,849
    So there not that much bigger on height than the emaxx width they are though looks like and man they are bigger than the e revo wheels.
    DEU 8:18 ESV
  35. #115
    9,244
    about 1/4" taller e max 11.54 oz vs 13.75 oz . about 2.21 oz heavier
  36. #116
    447
    what happened to the..."I'm gonna keep it stock"...???...ha ha...i guess that went out the door a while back...
    those are some nice wheels n tires....i see that u've already put in a big chunk of change like the rest of us...kudos man...u are officially a part of the dark side...
  37. #117
    9,244
    No kidding!
    I think I like to wrench on it as much as driving!
  38. #118
    4,849
    i like that pic you posted know i see how much thick tread those trenchers have compared to the emaxx tire wow huge difference i see for me. I just like the trencher look the side walls and everything if i am going to move out in the bonnies then i need a tire like that then will be doing some rock crawling and a ton of dirt and mud more likely since the road is dirt well live on.
    DEU 8:18 ESV
  39. #119
    9,244
    Yep
    I haven't glued a traxxas bead in a while. I will have to take my time!
  40. #120
    9,244
    Just checked tracking be here early next week
    Nice and strong!
