    23
    Rock crawler conversion
    Can I make a E-revo a decent rock crawler or should I buy a summit?
    Essex, UK
    154
    Hi if you got a three channel transmitter you can add to twin gear transmission, gives you a super low crawler gear, kit comes with servo to change to low gear
    Not sure about diff locks etched though.
    Feb 2008
    Fl
    3,062
    You could run some super thick diff fluid or putty in them to "lock" the diffs. Summit is pretty much a revo with long travel suspension and bigger axles, and locking diffs. You would need a sensored brushless motor to crawl as well.
    Sent from my Torch!
    7,262
    you need to buy summit diffs, bulkheads (you can use your e-revo driveshafts but i prefer using the summit driveshafts) and 2 micro servo, sevo mounts, diffs locking linkage. also if you want the 2 speed you have to buy the 2 speed conversion kit. so to put the hassle away, buy the summit and leave you e-revo the way it is.
    3,272
    Buy a Summit and then you have the best of 2 worlds ....I have both and use them equally as much .
    Rock n Rolla !
    kansas
    8,582
    It is impossible to have to many trucks......lol Sensored BL if you do turn your Revo into a Summit..
    Cheaper to buy a Summit...
