Thread: Tranny question
    Sep 2012
    Jacksonville, Fl
    628
    Tranny question
    Can I use the same white lithium grease I use on the diff gears in my tranny gears? On my erbe? It's the stock tranny also
    EMBE
    Jato 3.3
    T-Maxx 2.5
    Sep 2012
    Jacksonville, Fl
    628
    Anyone know if I can?
    EMBE
    Jato 3.3
    T-Maxx 2.5
    Riverton Utah
    5,384
    Some of the transmission gears (if they're made of plastic) don't need lube. You can lube the plastic gears anyway, it won't hurt anything, it might even help keep teh bearings lubed up. But if anywhere a metal gear is againest a metal gear, you'll need lube, other wise the metal gears will destroy them selves. Hope this helps!
    The Wolf is not concerned for the sheep's opinion
    Oklahoma City, OK
    2,688
    yes, you can use it - it will be fine
    "RED"
    Sep 2012
    Jacksonville, Fl
    628
    It is stock tranny not sure if they are metal, I saw 80t on one of his threads with the white gears and he had grease on there
    EMBE
    Jato 3.3
    T-Maxx 2.5
    kansas
    8,656
    yep put some in there....grease
