Results 1 to 9 of 9
    6
    3.3 Engine Performance Mod
    Just wondering what you guys think of this crank a guy is selling for the 3.3, coming from a 2-stroke background a little more porting of the crank should get some more power out of the 3.3, i need to stomp my buddys 3.3 & i think this might just do it.
    http://www.ebay.com/itm/Traxxas-3-3-...item27cb16ca01
    copy/paste
    7,261
    link not working, also look into swapping the carb, check out this thread http://traxxas.com/forums/showthread...u-need-to-know
    Kauttua city, Finland
    197
    I'm modifying my 3.3. It wasn't really that hard at all. I know there are some cheap (under 20$) "made in China" dremel copies and other similar rotary tools, that come with the necessary bits and you can get advice on the cuts just by looking aftermarket high performance cranks and there are also many forums where you will find topics about porting and other nitro engine mods, so I'd just do it my self. But nothing is stopping you from buying that crank of ebay, as that was after all only my opinion. Also I'd start on the outside of the engine, like getting a high performance pipe, better clutch and carb and stuff like that.
    |Traxxas|Revo|3.3|#5309|FIN|
    New York State: Snowbelt
    747
    If you buy that, tell me how's well it works
    191
    You might want 1 of these for your engine to
    http://www.davisdieseldevelopment.com/11-09-conrod.php
    May 2007
    West Coast, Fl
    2,132
    Quote Originally Posted by ozziii View Post
    I would pass on that and get one that has more refined work and finish.
    http://rbmods.net/rbshop/index.php?t...category_id=71
    RBMods
    392
    Now if you bought this would you need sleeve and all or what cause at the bottom Of the description it says 100 buck for it to basically withstand the extra rpm
    drive it like you stole it
    191
    Them rods do look better, I hadn't seen them, less metal would normally mean less strength though, but a lighter rod would help with higher RPM's. Be much better than the stock rod though.
    197
    Yup, the RB Mods con rod should be the way to go, as most 3.3 con rod problems are split con rods (The RB Mods con rod doesn't have a groove from hole to hole and the 2 grooves that the RB Mods con rod has are on the same side and the other side is solid) and destroyed upper ends, because stock upper hole doesn't have a bushing. Knife edging shouldn't make the rod weaker, maybe even stronger as it isn't trying to limit those high RPMs.
