    Milwaukie, Or
    285
    First Time Trying to Break in a 2.5 Having some problems.
    So I read and re read everything I could find about 4 times actually and I think I have the whole concept down but here is my problem.
    It was about 50 Degrees outside so I warmed the Entire T-Maxx in my Room plus Blastid it with a Hair Dryer for about 5 Min Prior to bringing it outside (Did not pre heat or warm the Nitro Though)
    Have a Brand new Ez-Start System complete Motor and Geartrain, New Fully charged 7.2V 1500 mah Traxxas Battery. When I first went to attempt to start it the Engine would crank about 1-1/4 Turns then stop, realized I had forgotten to Clean out the engine from the WD-40 and Marvel Mystery oil I had Sprayed in it to keep it from rusting/corroding while it was stored so I removed Glow plug and cranked to a few times and it cranked over nicely and spewed out the extra oil I had in it so I thought all was fine.
    Not so lucky as soon as I installed the Glow Plug it appears the engine has to much compression for the EZ-Start System, Just to be sure Put the battery on a Pulse/peak charger until it registered full and Tried it again and same thing, I got the engine to fire then it flooded.
    Removed the Glow Plug again and Followed Directions to unflood and it spewed out the fuel, I disconnected the Pressure line from Resonator Exhaust just to be sure re-installed Glow plug and Tried again and It fired up , so I re-attached Pressure line and again it appears I have so much compression the EZ-Start system cannot spin engine fast enough to fire engine when Glow plug is in as it gets maybe 2-3 revolutions before the ezstart system stalls.
    A couple times it stoped at TDC which is a Pain as it is really Tight there, whats got me puzzled is without the Glow Plug The engine Spins nice and fast and continous with not stalls or hesistations but with glow plug in it has such a hard time turning engine over.
    Is this Kinda normal on a new Engine?
    I was thinking of trying tomorrow much earlier in the morning so I have more time to work with it and I was thinking maybe I should warm up the Nitro too?
    I also found my Glow Plug that was in it takes a bit to Glow where my 2 New 3232X plugs Glow red almost instantly so I am going to use one of the 3232X's and put the One the engine came with of to the side until I figure out why it has such a delay in heating
    Do you think that may have been some of my problem? Having a Tight engine to begin with then a Glow plug that was allowing to much fuel to get into engine creating extreme compression?
    It did not occur to me at first as I was only getting about 1-2 revolutions before the EZ-Start would Stall but now that I think about it maybe that was all it took to stall the ezstart system.
    Any suggestions on what would make this easier would be appreciated, and like I said without the Glow plug in the ez-start systenm can crank the engine quite nicely as I made sure to blow out all Fuel and I did the after run procedure with wd-40 about 6 times to be sure I had nothing in the engine to cause corrosion and the engine spun nicely with all sorts of wd-40 in it so I know the EZ-Start system can crank the engine over and I am sure there is no Sign of anything to attract moisture in the engine now.
    What I mean by now is I know the engine will not have any damage overnight so It will be just like I am starting with a brand new engine in the morning, this time though I will use a new Glow-plug.
    Should I (after warming the engine up real good inside and with a hair dryer, remove the Glow Plug and crank it a like for the count of 3 to spew out any oil that may have settled overnight and to sort of warm up the ez-start systen to get all the gears and so on loosened up since it is a new system?
    191
    They are set pretty rich from the factory, I found I had to lean out my LSN a small amount to get mine to fire as it was getting way to much fuel, it helped get it going. Stick with the good glow plug to, that will make a difference. Warming the engine with a hair dryer is the way to go, helps expand the engine parts & will make it easier to turn over, warming the fuel won't do much & cooler fuel is actually better, ignites easier & produces more power. You shouldn't need to loosen up the easy start system, it won't make a difference. Also, you don't need to spray so much WD-40 into the engine, I used to just spray some down the carb & into the glow plug hole then after a few minutes to let is get through the engine I would give it a quick turn over to get the excess out. It only needs a light coating on the engine parts to protect them from corrosion.
    Milwaukie, Or
    285
    Ok Thanks, ya I remember the Truck when I first got it I was not sure what the Proper Setting should be so I set the carb to factory and I know when I was Fine tuning it I had to lean it out quite a bit , I think it ended up being like 2.5 turns out instead of 4 although the LSN was about the same 1.5 out.
    I will Be sure to use the New Plug that actually heats up correctly, I was shocked that the Other Plug did that as it is brand new too, I guess from now On I will test them all before I install them, Maybe I will try the HSN at 3.5 and the LSN at 1.25 out and see how that does, once I get it running I can richen it up if i need to .
    BTW I think you may misunderstood what I meant by Loosening the EZ start system, I was meaning to Crank over the engine a little without the glow plug to get everything moving, although since it is not like an engine with oil or has heavy grease in it I doubt cranking the System for a few seconds would allow it to spin faster or easier as it would if the EZ system was full of grease or gear lube.
    10,125
    Start with all the needles at factory settings. A new piston or sleeve--or even a repinched one--is pretty tight so your issues does not surprise me. You can loosen the glow plug a little bit to relieve the compression while starting and once it is running tighten it up.
    And go light on the WD-40. You don't need to bathe the internals in it, just a light shower enough to get a very light coating.
    90
    best thing i ever did when i broke in both my new 3.3 motors, was i ditched the EZ start systems for a pull start. piece of cake then. these motors are so tight when new, they burnt up one of my EZ starts and the other one didnt have the nutz to get it past top dead center.
