Results 1 to 11 of 11
Thread: battery help
    495
    battery help
    ok i ordered 2 traxxas 2s 7600mah 25c batteries a month ago the first battery i charged was fine then plugged the second one in and it had a unbalanced volt of 35 so i let it charge worked fine then when recharging iit was 165 mv unbalanced so i emailed the guy i got it from and he said send it back so i did got the new one today popped it on the charger and it is 43mv unbalanced so my question is should i send this one back to?
    kansas
    8,178
    well it is not good, sometime after a few cycles they will balance out. so up to you what you want to do, including contacting the dealer.....gl2u
    495
    Thanks for your help
    kansas
    8,178
    sure jmo I would cycle them a couple of times, then try to decied from there.....
    also take it easy breaking in the batts..
    495
    i never knew i had to break in batteries.how do i do that?i usually charge them then just go use them.i got the one that was saying low voltage to charge after letting it sit for a day and the other had 105mv unbalanced but it also charged.just cant use them since we are getting hit with this hurricane.the batteries i am having problems with are the traxxas 7600mah 25c 2s batteries. the only problem i had with the 8200mah 2s spc batteries was a bad soldier job on the red wire
    kansas
    8,178
    I just take it easy for the first several runs, light pulls on the throttle & not just holding full throttle...
    The balance prob, that is way out of balance..Might have to cycle them a few time see i fit will balance back..
    495
    ok ty so much for your help
    kansas
    8,178
    have you take cover??
    495
    yeah we're all good its all over now just had like 75-80 mph winds got very lucky and never lost power.usually if i farted the power went out lol thanks for caring
    kansas
    8,178
    Good the hear, going to need an arm of people for the clean up..
    495
    yes it will i am going to ocean city tomorrow to check on a job we are doing there i hope its still there
