    friendswood texas
    1,555
    how much grease?
    Did a complete overhaul. How much grease should I put on the ring gear? I got the differentials where the spider or small gears are filled properly but the main or ring gear I am in question of. I coated the ring and pinion gear in grease (lucas red and tacky) ran the truck and then disassembled and checked. It looked too dry after one pack soo I added more now it wants to push out around the bearings for the drive axles. I know its not the OIL leaking because its red and too thick.
    HESPERIA, SoCAL
    248
    Just a light coat around the ring gear. Rotate the pinion gear a few times to spread it out. Doesn't take much grease.
    Sent from Mars Curiosity.
    Aug 2012
    Central NJ
    1,245
    I put none in the differentials and fill those with oil instead.
    For the ring gear a light coat is all that is needed.
    friendswood texas
    1,555
    Thats what I thought judging from what was there originally but I was worried about it going dry so I added more mabye too much.
    Aug 2012
    Central NJ
    1,245
    No worries if you got to much, it will just sling it off.
    I dont usually use the Traxxas grease. I just coat them lightly with sprayable lithium.
    Dec 2009
    MN
    786
    T A makes a very nice product for this application called black grease #6588
    Slash 2wd
    Slash 4x4 MT
    P4de Trail
    Davenport, Iowa Quad Cities
    2,471
    I fixed another fellas merv and ordered the traxxas grease myself. I started to clean and tear down our other diffs since I was bored.
    friendswood texas
    1,555
    Quote Originally Posted by JustinThyme View Post
    You are soo correct I was paranoid about it today after running a couple of packs so I tore it all down again and to my suprise all the excess grease was slung away from the gears. YES I used WAY too much and now I know. STILL a stupid noob here.
