Results 1 to 9 of 9
    5
    channel four on a tq 2.4ghz?
    how can i make the middle position the neutral(no power to it basically) on the fourth channel? ant help would be greatly appreciated
    5
    sorry *any*
    12,316
    Fourth channel??
    Are you talking the thumb switch? (Channel 3)
    Or a Summit specific locker switch? (Channels 4 and 5)
    EDIT:
    I forgot that Traxxas also uses the Summit remote for the Drag cars.
    5
    i'm talking about the 3 position toggle switch on the front of the radio(channel 4)
    12,316
    That toggle switch is channel 4 and channel 5, not just channel 4.
    Channels 4 and 5 are half channels... they only have half travel; they only travel from center to one side and back.
    The switch might be able to be wired in such a way that
    position 1 throws channel 4
    position 2 (center) returns 4 to center
    position 3 throws channel 5
    EDIT:
    Come to think of it, you can get the same effect by reversing channel 4.
    5
    ok but how do i cut power to the middle switch position. i've already tried removing wires. that does not work. any other suggestions? or am i effd?
    5
    what i'm working with is a rc4wd 9300xt winch. i need a neutral position so the winch isn't constantly working.
    1,892
    for a winch you'd need to use ch3.
    12,316
    This is correct.
    As I said in post #5, channels 4 and 5 are half channels.
    Channel 3 is the only channel possible for a winch.
    This thread will give the thumb switch a center off position:
    http://traxxas.com/forums/showthread...ter-off-switch
