Results 1 to 2 of 2
    Jan 2010
    Central Florida
    650
    LED question....
    This is the first time I've seen this... While crawling, my front white LEDs turned a dim green then turned off... I'm guessing the lights(4) blew and I will need to replace them. But I have never seen that before... I m running a voltage regulator to limit output to each bank (3) at 4 volts max each. Do you think this is a problem with board or LEDs.
    I will be taking the truck apart again to check voltages and lights but I was wondering about the use of boards this was a first for me, normally I direct wire, is this green glow before burnout normal?
    Anyway the board claims it can handle 7.2 - 12volts. I was using an 8.4 nimh pack for power... Any insight is helpful....
    Thanks
    The original CRASHER : equal parts CRAwler and baSHER!
    Sent from my mobile device
    Just do it...they make replacement parts.VXL power
    Jul 2010
    London,KY
    316
    I've had more than a few Leds get the green glow before they died, always from to much voltage. Now this wasn't on a Summit, just some little projects a while back.
    Sounds a little weird to me though.
