    Delaware
    1,178
    How do I turn off my VXL-3s?
    To the men and women of the US military, thank you
    muscoda, wi
    1,245
    unplug the battery. when my vxl-3s is blinking red from lvc sometimes the button wont shut off esc. so i unplug battery.
    Delaware
    1,178
    can pushing the button cause a problem?
    Zeeland Michigan
    1,230
    Quote Originally Posted by TraxxasTuesdays View Post
    Know it won't turn off , You hv to unplug it .
    1 Rusty VXL
    RC Champion dave00bear's Avatar
    Jan 2007
    Michigan
    1,914
    The VXl CAN be turned off by simply pushing the EZ-set button. Just like when you turn it on.
    Two inserts from the manual
    7. To turn the VXL-3s off, press the EZ-Set button until the
    LED turns off (.5 seconds).
    The VXL-3s does not use a conventional on/off switch. Pressing the
    EZ-Set button on the speed control turns it on and off. It is not necessary
    to install an on/off switch into the wiring harness.
    My previous sig conflicted with a forum policy.
    Zeeland Michigan
    1,230
    Quote Originally Posted by dave00bear View Post
    When mine is blinking , I've to unplug battery . I'm running 5000 SPC 3C 25A .
    1 Rusty VXL
    Snow Belt, Ohio
    372
    Quote Originally Posted by rhardy60 View Post
    Same here...when LVC kicks in you can only turn it off by unplugging the battery. Any other time you can just push the button.
    Delaware
    1,178
    But holding the button can't cause a short circuit and fry my ESC as CastleWoodsRC suggested HERE?
