Results 1 to 13 of 13
    RC Racer stanleyd's Avatar
    michigan
    117
    stock xl5 speed run
    I ran 31 mph with titan 12 t 28/86 gear and 5000 mah battery, it was cold about 45, would the car run faster if it was warmer? First pass was 26, after about 6 passes the best I could get was 31. would a 83t spur help with the 28 pinion? thanks Stan
    waterloo .on.canada
    2,292
    well umm warmer is wores
    heat is the enimie in the world of electric
    if your out side temps get lower you can gear up or if the 12t is below 160f then you can gear it up also
    that battery is it a lipo or nimh?
    Worcester, Massachusetts
    1,399
    32p gearing will make your vehicle faster
    SL4SH Mamba Monster-Rustler Mamba Max 2400kv
    michigan
    117
    venom 5000 mah nihm
    michigan
    117
    please elaborate
    waterloo .on.canada
    2,292
    32p lie's
    it dosent matter between 32p or 48p
    michigan
    117
    does 31 mph sound about the norm for this set up?
    michigan
    117
    would the 83t spur give better results?
    7,176
    You can drop the spur gear down, but it takes like 6 teeth to notice a difference. Most of the time it's used to fit a taller pinion on for added room if the motor is shoved all the way to the back of the gearbox. Yet at the same time adds more choice of gearing.
    I'd be careful at gearing to tall it won't take much to overheat that Titan 12T. Then comes amp draw, this could fry your electrics & burn up the motor. I'd move up to brushless and then not have to worry about most of any of that. A temp gun is your friend if you are going to make speed passes like that.
    Hope this helps!
    Weak Revenge
    Strong Forgive
    Intelligent Ignore
    michigan
    117
    thank you for the info and advise, I mainly do off road but was curious as to what top speed would be,Stan
    Arizona
    2,376
    31mph is good for a stocker. I would be happy and not melt the motor lol unless of course if you melt the motor your going to upgrade to brushless. . In that case gear it tall and throw in a 3s lipo lol Weeeeeeee. BOOM.
    NEW MOTOR !
    1 Slash 3 Rustys & visits with my old P4de/SC8
    49
    I have xl-5 which is now upgraded all the way around but I wouldnt suggest continue using that gearing IMO you will fry that titan just like they are known for doing.
    michigan
    117
    yea I am saving for the brushless, but am enjoying the titan for now, also run titan 21t with 23/83 and it doesnot get hot and tops out at a blistering 17mph!
