Results 1 to 12 of 12
    12
    strc lcg conversion problem
    Just bought the strc lcg conversion kit as well as the upper& lower rustler chassis pieces. After transferring my slash servo over to the rustler chassis, there is a clearance problem. Has anyone else run into this problem? Wondering if I should just use my dremel to fix the problem or buy the rustler servo instead. Thanks for any help.
    105
    Should be the same servo. Can you be a little more specific on the problem? Pics maybe?
    Pomona CA.
    325
    That's why I keep my Slash Traxxas ,strc seems well but I gain skillz killin modified ish.
    Traxxas Slash 2wd and Thunder Tiger Tomahawk Vx
    delaware
    936
    is your servo horn to big
    330
    Yes, Dremel, no... Using stock servo (2075) and stock servo saver it wouldn't "throw" all the way to one side.
    I had to hack the top piece up with a dremel. Unfortunately, I was at the track between heats so I didn't have time to do it pretty. I also hacked a chunk out of the side of the chassis so I could get to the screw to make adjustments to the servo saver with everything mounted.
    But that fixed it.
    Malone NY
    34
    i have a rustler too and i got the conversion kit i didn t have any problem. my servo is 2056 so it may be a little smaller. right were your servo horn is i found it rubbs sometimes and i just sanded it thinner there and havent had any problems
    12
    No way of posting a picture now but it is the steering horns hitting. They seem a lot fatter than the rustler horns. They are hitting a lip on the lower chassis. I can easily trim it out on each side with Dremel but wanted to get some opinions first. I can try to post pictures tonight.
    Sep 2011
    Apple Valley, MN
    81
    I had to cut out a bit when I installed my kit. I just used a razor saw. This is the right side.
    Sep 2011
    Apple Valley, MN
    81
    Here's the left side.
    12
    Thanks Road Rascal. That's exactly what mine looks like. I'm gonna cut it out just like you did. This forum is awesome.
    Sep 2011
    Apple Valley, MN
    81
    Glad we can help! I know I read (either on this forum or another) about cutting the tray a bit to get the steering working properly. I just copied what someone else did, so I can't take the credit for the mod.
    South of St Louis
    6,298
    I did the same with my Slash lcg but it wasn't that pretty... I used a set of snips until I had time to clean it up with a Dremel.
