Page 1 of 2 12 LastLast
Results 1 to 40 of 55
Thread: My slash 4x4
    Delaware
    473
    My slash 4x4
    Figured I'd throw up a few pics of my slash.
    Mmp/2400
    21/50 gearing
    Revo slipper/alum slipper pads
    Gh motor mount
    Trx bearing adapter
    Strc finned motor plate
    Mip axles front and rear
    Venom 4s lipo
    Dynamite 3s lipo
    Rustler receiver box
    I think that's it...
    Canada
    275
    Why that motor mount over the King Headz?
    Delaware
    473
    Quote Originally Posted by bruggar View Post
    It was cheaper, uses the same oversized bearing as the king headz, and was in stock at my lhs...
    Dec 2007
    Manassas, Va
    6,842
    I think i might try the GH mount too. i've always liked their aluminum. nice truck! it looks like you need new tires soon.
    I race Associated, I bash Traxxas. 28 years in RC
    Delaware
    473
    I'm happy w the gh mount. Nothing bad I can say about it.
    I had a set oh trenchers on j concepts wheels, but I had a wheel nut come loose, and the hex inside the rim turned into a nice circle. I have proline beadlocs and switch tires on order. Should be here tomorrow
    Davenport, Iowa Quad Cities
    2,471
    looks good. I don't like my gh mount at all. Has a 3mm gap that lets sand in. I picked it up cheaper than the KH. I wished I gone with the kh. But I'll use the Gh and seal the gap. Nice build btw!
    Delaware
    473
    Thanks knuckles. I run mine without the gear cover anyway... I really don't bash but in grass and harder packed dirt, otherwise it's asphalt. I had one instance where some mulch got into the gears with the cover on, and I feel like the cover kept it in there.
    One other thing I want to do is buy a new stock chassis and dye it black. The stock one has some deep grooves cut in it from landing on rocks and such.
    Central NJ
    1,245
    Looks good! Your body is in much better shape than mine. Got a flotek ford body on the way. Im too embarrased to post up pics of my manta body now LOL
    Did you add padding to the bottom of the MMM mount for the MMP? It makes it set in there a lot more snugly. There is also a mount that is made specifically for this by a company snappyrc.com. They make a mount for both the regular position and one for the position like you have to allow the longer can motors. They also include screws for mounting the switch. Bought one for the 4x4 my 10 yo son is building now.
    Seminole, Florida
    439
    Looking good, you might want to run the antenna wire under the steering servo lead. When you get he powerstrokes you will notice a marked improvement in handling. Your shock positions look fine, I tried to move the fronts to two and I body rubbed even with reds. Have you considered a clear spur/pinion cover?
    Slash 4X4, MM 2200kv
    MIP CVD
    Tekno Bigbone
    Delaware
    473
    Quote Originally Posted by JustinThyme View Post
    No, I actually cutdown the posts on the mount itself about 1/8-1/4 inch and used shorter screws to secure it to the chassis. In not interested in the snappy mount, because this mount cost me 3.00 and works perfectly fine.
    delaware
    936
    nice truck man . have you tried metal hexes
    HESPERIA, SoCAL
    248
    VERY COOL!!!
    Sent from Mars Curiosity.
    Lake Jackson, TX
    1,457
    looking good! I do believe your intake fan is backwards, not that it makes a big difference
    edit: I see that it probably wouldn't reach the rx box the other way..nvm
    Pro-2 SCB 2xSuperMaxx Revo-E SCT410
    Grassie Ontario Canada
    3,136
    You say it's a mmp but it's actually a mmm...
    How do you like that venom battery?
    Now see with a closer look.. Mamba monster extreme!
    Delaware
    473
    It is infact a mamba max pro...
    I've only put 1 cycle on the venom battery, but so far I like it. It's a snug fit in the battery tray of the slash. Not thickness wise, but length wise.
    Feb 2010
    El Sobrante, Ca
    9,553
    Great job on upgrading your truck! If you glue your hex into the wheel you can still use them. I solved this problem with aluminum wheels and hex. Nothing to strip out.
    Slash Ultimate, ET-3S 2400 MIP King Headz RPM 3PL
    Delaware
    473
    I was thinking about glueing the hex. I also may try to remove the tires from the rims. If I could save the tires, I'd use them on my beadlocs
    Seminole, Florida
    439
    Quote Originally Posted by Cinnabun View Post
    You could try that, but if they are glued to a wheel removing the CA from the tire would involve a hobby knife and sore thumbs. Acetone melts CA but discolores plastic as well. I don't believe at that point the removed tires would sit well in the beadloc. What really impressed me when I originally assembled my trenchers was how well they seated. My disdain for CA comes from my RC plane days, you have to use it constantly and I grew to hate the smell and getting it all over my fingers. If I can use beadlocs, have a good tire selection, and reuse rims then I'm good.
    MIP CVD
    Tekno Bigbone
    Delaware
    473
    Went outside to do some speed passes... And well I have my first slash mishap. Regeared to 21/52.
    3s.. 49.4mph
    4s.. 55mph before the mishap
    And, the mishap.. Torque steered into a curb when I pulled full throttle and the tires broke traction...
    Snapped the arm at the hinge pins and split the shock body. ****it
    Sl4sh mmp2400 - savage flux hp XL - vorza flux hp
    Lake Jackson, TX
    1,457
    bummer! time for upgrades
    Virginia
    403
    RPM A-arms and better shocks. I run the Traxxas big bores, but there are a lot of other options out there.
    Slash 4x4 stock
    Slash 4x4 MMP 2400
    KB Fiesta
    Delaware
    473
    I'm going to get rpms from the lhs tomorrow, and a fellow member is selling me a set of proline shocks
    3,136
    How's that a mmp though?? Does it just have the mme casing?
    Delaware
    473
    That is how the mmp sct looks I guess? I don't know really, I pulled it out of the castle packaging and installed it. Possibly the esc mount is throwing you off? The mount is from he brushless e revo.
    Central NJ
    1,245
    Sorry to hear about the mishap.
    Funny how those curbs jump out to get you.
    The RPM towers tend to flex instead of snapping like stock.
    Delaware
    473
    Getting rpm front arms tomorrow, and a stock shock body until my powerstrokes are here
    3,136
    I have the sct mmp and it has greenish plastic on part of it.
    That esc is from an xo1
    Delaware
    473
    It's an mmp, I'm telling you lol
    Here you can see the green sticker...
    3,136
    Okay.. So do you use the mme casing to help cool the motor more ?
    Delaware
    473
    I don't have a mme case. That is a stock mmp from castle...
    Seminole, Florida
    439
    Cinnabun , I was able to get 50/24 to fit, have not run it yet, you guessed it. Raining in St Pete. Let you know if speed increases. Let me know when the shock arrive.
    MIP CVD
    Tekno Bigbone
    Delaware
    473
    Got my split six beadlocs and switch tires today, rpm front arms, and aluminum hexes. Didn't get any quality run time on the switch tires, but then seemed to hook up ok in the grass.
    Seminole, Florida
    439
    We you sure those are beadlocs?? Lol
    MIP CVD
    Tekno Bigbone
    Delaware
    473
    Heading back to the lhs to grab a tekno big bone. I found the center driveshaft actually has a split where the rear splines are.
    Seminole, Florida
    439
    You will find it sets up tight, set the two washers in each cup
    MIP CVD
    Tekno Bigbone
    Central NJ
    1,245
    I love the Tekno Big bone. Put all four of the rubber o rings that come with it in. 2 in the front cup and 2 in the rear and the front to back slop goes down to like 1/8". I did the same thing 3 times with the "tubed spline" design. Two stock and one Integy to see if it was just the stock being weak, it wasn't. I even tried to bush the ends so it stayed centered better giving the splines better bite on both ends. It lasted a little longer but in the end the rear contiuned to split the shaft. Oh the joy of running 454 big block in a chevy vega. And yes I did that too once upon a time. Liked the look but nothing would hold up to the power. Ended up keeping the body and scraping the entire chassis for a camaro chassis. Funniest thing I did with the stock chassis was when I couldnt get traction so bled rear tires down to 10 psi. Got plenty then, snapped all the lug bolts off the rear end and her butt sat down on the tires! Im too old to build hot rods now so I apply the same principles to RC instead.
    Delaware
    473
    The accident spot. Lol
    Seminole, Florida
    439
    No chalk outline?
    MIP CVD
    Tekno Bigbone
    Central NJ
    1,245
    Quote Originally Posted by Dgb007 View Post
    No chalk outline?
    shaped like a slash 4x4
    Some serious scrapes on the concrete! that was a hard hit, Suprised you didnt get more damage than you did.
    Delaware
    473
    So I've been battling with a rear end wobble for quite some time now. I kept thinking it was my wheel nuts loosening.
    After running it today, I got frustrated enough and suspected the plastic rear hubs make have lost tolerance in the bearing seats.
    But wait... I thought the balls were supposed to be inside the bearing...
    Going to need to pick up new wheel bearings, and probably aluminum hubs...
