    Port Macquarie, Australia.
    9
    Help, Tip's & feedback All Appreciated.
    I currently run Stampede Talons (front & Back) On my Stock Slash VXL 2wd.
    I run my VXL on 2s Lipo's with the Standard out of the box Pinion/Spur gear set-up.
    My question is: (1) Do I need to change My Pinion/Spur gear set-up?
    (2) Is it wise to change my Steering Servo? Is the Added weight and overall tyre size putting it under pressure.
    I am happy with the speed and in general happy with my Overall set-up. I enjoy running the Talons But worry I may be placing my Slash under Pressure.
    I am new to the RC Hobby and if this question has been asked before I appologise in advance. Just leaning how to use the Forum at the moment.
    Grassie Ontario Canada
    3,138
    Im 90% sure the 2075 servo (yours) is stock on a pede 2 wheel drive.
    What is your gearing?
    9
    My gearing is Pinion 23/86 Spur gear.
    3,138
    Okay if you have lower gearing like 19/90 should be good
    Brooklyn Park, MN
    1,249
    Servo should be fine, it is the same one on the stampede, you will want to lower your gearing though.
