Results 1 to 15 of 15
    Grassie Ontario Canada
    3,138
    Need help with my slash 4x4
    Hey guys. My slash 4x4 has a problem.
    So about a week ago I brought it out and it wouldnt move and there was a burning smell picked it up and pressed the gas tires moved.
    So my problem is it won't move under load. I'm 85% sure it's not the front diff and I've checked the rear twice. Also the burning smell was from the slipper clutch area. I have no idea anymore
    Help Please
    Jul 2012
    Seminole, Florida
    439
    Are the pads worn on the slipper, if so replace part number 5552
    Slash 4X4, MM 2200kv
    MIP CVD
    Tekno Bigbone
    3,138
    Nope they aren't worn out
    Farmington, NY.
    14
    Check the plastic bearing adapter between the slipper spring and the spur gear on your slipper assembly. Get the $5.00 aluminum Traxxas piece that replaces the useless plastic junk. You may need one or both of the bearing that this piece contacts depending on how hot it got.
    Mike
    Oct 2011
    Worcester, Massachusetts
    1,399
    buy the revo slipper with aluminum pads and aluminum bearing adapter
    SL4SH Mamba Monster-Rustler Mamba Max 2400kv
    RC Turnbuckle Jr. Carbonrevo33's Avatar
    Jul 2008
    In a box on Hwy. 64 bashin' with Bradley Youngskins!
    3,979
    Sounds like the stock bearing adapter is out...melted...
    3,138
    It was the bearing adapter it melted. Does this mean my motors to hot?
    12,603
    I think your motor is shot. See if the shaft moves when it is on the ground and are giving it gas. If it doesn't the motor is done.
    3,138
    i mean the bearing adapter part 6893 (i think thats the part number) melted
    so the bearing adapter in the spur gear area did the problem. it also stuck on the metal spring.
    i was just asking if you guys thought my motor got too hot causing this. nothings wrong with my motor
    RC Turnbuckle Jr. vxlrocket's Avatar
    Dec 2007
    Manassas, Va
    7,117
    Quote Originally Posted by kdvanb View Post
    ideally, you need to keep your motor under 180 degrees. what can cause your issue is a bad bearing as a result of the plastic adapter melting. it's better to upgrade the adapter to the aluminum one.
    "It's just RC, not rocket appliances"-Ricky
    3,138
    but how hot do you think it got since the bearin adapter melted
    Dec 2007
    Manassas, Va
    7,117
    it's impossible to tell. maybe not hot at all. it just depends where the bearing broke down and caused enough friction to melt the adapter.
    3,138
    okay. hopefully i can go to the lhs soon because both of my trucks are doiwn. maybe in another month or so. i hope not though.
    gonna upgrade to part 6893X ( aluminum)
    Ontario, Canada
    1,191
    Save yourself the trouble get a King Headz motor mount and bearing adapter. See ebay for a cheap used KH . It's one of mine, I sold the truck separately.
    3,138
    El Sob I think you were right. Replaced bearing adapter and it still won't run
