Results 1 to 10 of 10
    Sep 2012
    Port Macquarie, Australia.
    9
    Tyre/Wheel Combo for off road racing.
    I am after some tips/Ideas on what the best Off Road (Racing) tyre combo is for my Slash 2wd VXL.
    I race at my local track & with the standard tyre/wheel combo that you get out of the box find that I spend more time spinning out then getting anywhere in a hurry. Thanks for taking the time to read my post
    Atlanta
    996
    What kind of track conditions are you running? But no matter what, these are probably the best multi-surface racing tire. These are already pre-mounted.
    Front Wheels:
    http://www.amainhobbies.com/product_...-2-Slash-Front
    Rear Wheels:
    http://www.amainhobbies.com/product_...n-2-Slash-Rear
    330
    All depends on the dirt. We have a hard clay track that when it is damp one type of tire works and when it dries out, we have to switch to another type.
    Then we have a track that is deep loamy dirt and neither of the types mentioned before work.
    Then we have a track that is sandy and you need yet another type of tires.
    Nobody on the internet can tell you what type of tires you need for your dirt!
    Sep 2012
    9
    My track its hard compounded dirt with a soft layer of dirt on top. The dirt is picked up easy and spat round.
    Trying to take a corner at speed is useless in the slash VXL as its just spins out of control. So I need the maximum amount of grip on a super soft dirt surface! It's never wet. The tracks only ever used in hot dry temps. Thanks for the feed back so far.
    South of St Louis
    6,250
    I use proline calibers at my track. Best thing to do is ask someone what they use at your track and then try them.
    Grassie Ontario Canada
    3,138
    I think proline gladiators will suit your needs
    Feb 2008
    SoCal, USA!!
    728
    Handling conditions from loosest on top to firmest on top:
    PL Gladiators --> JC Subcultures --> PL Calibers
    The description the OP gives sounds exactly like the conditions on my track. Always dusty and dry. Any tire with a stepped lug pattern will do. The Gladiators are a little more plush than the other two, so they bite a bite better in the loose.
    Brooklyn Park, MN
    1,249
    How do the gladiator sc hold up on only street? I had a 2.2 set on my truck and I burned them up so fast.
    Samsung Epic - Tapatalk 2
    MM|2200kv 2WD LCG Slash - MM2|2650kv LCG Slash 4x4
    Feb 2008
    SoCal, USA!!
    728
    Same tire on a different rim. The SCT version would wear just as fast. No step pin tire should ever be run on pavement/concrete.
    Sep 2012
    9
    Thanks for the feed back Everyone.
