Page 2 of 2 FirstFirst 12
Results 41 to 52 of 52
Thread: ERBE Upgrades
  1. #41
    60
    I think I want an entirely separate crawling system so I guess brushed is the way to go. The MMM can handle brushed motors right?
  2. #42
    kansas
    8,316
    idb so...........
  3. #43
    60
    this might be a dumb question but I couldn't find out what idb means. could you tell me?
    Thanks
  4. #44
    kansas
    8,316
    I
    Do
    Belive
    all good here is a few more, IDK all them either................hahahhaaaa
    Terms:
    BEC: Battery Eliminator Circuit
    UBEC: Ultimate (or universal) Battery Eliminator Circuit
    ESC: Electronic Speed Control
    BL: Brushless
    COG or CG: Center of Gravity. "Cog" could also mean motor cogging, but the letters are not usually all capitalized.
    CD: Center Differential
    MM: Mamba Max
    MMM: Mamba Monster (Max)
    MMP or MMPro: Mamba Max Pro
    RPM: Revolutions per Minute or the RPM company
    KV: RPM per volt motor constant
    Y or Wye or Asterisk or Star: A brushless motor coil configuration. Looks like the letter Y.
    D or Delta or Triangle: A brushless motor coil configuration. Looks like a triangle.
    CC/CV: Refers to the Constant Current/Constant Voltage threshold for lipo charging.
    CC: Castle Creations company.
    LMT: Lehner Motoren Technik brand of brushless motor, commonly shortened to simply Lehner.
    S, L, XL: Refers to the motor can length when talking about Feigao/Wanderer/Nemesis brushless motors.
    S&T: Sky and Technology company - makes the Quark ESCs.
    MGM: ESC brand.
    AC: Alternating Current
    DC: Direct Current
    PWM: Pulse Width Modulation. Refers to the method ESCs use to send partial power to a motor. Highly efficient. Can also refer to the signal from a radio receiver to servos/speed controllers.
    Rx: Receiver.
    Tx: Transmitter.
    RCM: RC Monster. Can refer to the main site, the forum site, or "the man" Mike.
    LVC: Low Voltage Cut-off device to protect the lipo cells from being discharged bellow 3V per cell
    HV: High Voltage
    FET: Field-Effect Transistor. High current devices used in speed controllers that channel battery current to the motor.
    MOSFET: Metal-Oxide Semiconductor Field-Effect Transistor. Other less common versions: Metal-Oxide Silicon Field-Effect Transistor, and Metal-Oxide Substrate Field-Effect Transistor.
    NiMH: Nickel Metal Hydride Battery
    NiCD: Nickel Cadmium Battery
    Lipo: Lithium Polymer Battery
    Cap: Actually not an acronym, but an abbreviation for capacitor.
    A: Amps. Electrical term for current.
    V: Volts. Electrical term for voltage.
    W: Watts. Electrical term for wattage or power. 1 horsepower = 745.7 watts.
    mAh: milliamp-hours. Battery capacity rating. How many milliamps a battery can deliver for one hour. There are 1,000 milliamps (mA) in one amp. So 1000mAh is the same as 1Ah.
    WOT: Wide Open Throttle
    Forum "shorthand" acronyms:
    IIRC: If I Remember Correctly
    ATM: At The Moment
    IMO: In My Opinion
    IMHO: In My Honest (or Humble) Opinion
    BTW: By The Way
    OTOH: On The Other Hand
    AFAIK: As Far As I Know
    FWIW: For What It's Worth
    FYI: For Your Information
    ATB: All The Best
    FTW: For the Win
    IDK: I Don't Know
    IDB: I Do Belive
    GL2U: Good Luck To You
    PM : Personal Message
    MP : Market Place
  5. #45
    60
    Thats a lot more than I expected.
    Thanks
  6. #46
    60
    So from all of this I have come up with:
    -Long travel rockers
    -Spring loaded wheelie bar
    -Lipos
    -4 channel radio with the docking base
    -2 speed transmission
    -Telemetry censors
    -Plasti dip the servos
    -Water proof the MMM
    -TVR/Summit drive shafts
    -T lock diffs (maybe I can find/make a metal locker)
    -Chassis brace
    -Tape the tires
    -Extended summit rear A arms (do they fit all around without looking funny?)
    -A motor mount mod
    -A brushed motor for crawling
    -Summit bulkheads
    -The XO-1 1717 motor
    -The Mamba XL (can it run brushed?)
    -An aluminum slipper clutch
    These things aren't in any order yet so please give some input.
    Just curios if it would make a difference to remotely operate the wing. I probably wont do it (not enough channels) unless I can find a way to link the position of the wing to the speed of the car.
    As I replace bearings should I upgrade to ceramic or stick with the stock ones.
    Any recommendations are appreciated. Thanks.
  7. #47
    kansas
    8,316
    no, not for what they want for a set, jmo, but you can run them it's up to you.....
  8. #48
    60
    Just thought of this, what if I used a gyro on the wing to control it so when the back end goes down the wing compensates to bring it up again and vise versa or would I still need another channel to plug it all into?
    Really what I should be asking is if its necessary?
    Thanks.
  9. #49
    kansas
    8,316
    Ive got nothing to really add
    will be interesting & not real sure why you need it, first crash it might be all for not..
    then again this is a hobby...lets see what you come up with...gl2u
  10. #50
    60
    So I just went to the ERBE page (for some unknown reason) and I noticed a price change, does anyone know why?
    http://traxxas.com/forums/showthread...des-for-racing
    In post two it says something about variable damping pistons, can someone give me some more information? Also in post four I think those chassis are pretty cool but would they be week or let a lot of dirt in? If not than I think it might be on the list.
    Thanks.
  11. #51
    3,271
    Here mate...read post #32. I have a pic in that post so you can see what it looks like. It comes with a valve flap that you can instal on the top or bottom depending what you want from your truck. Mine is on the bottom for bashing .
    Rock n Rolla !
  12. #52
    60
    No more comments or ideas on the price change, chassis or wing?
