    Oct 2011
    Dirty Jerz
    264
    many problems with my p4de. please help
    It all began when i broke my front center drive shaft and replaced it with a hardened steel one. while i was doing that i took the time to tighten my slipper clutch. I put everything back together and ran the truck. I stripped my delrin spur gear which was supposed to be stronger than the stock. I replaced the spur gear and noticed that after the truck was put back together the rear wheels wouldn't spin freely. Also when I turned the wheels by hand the slipper clutch wouldn't turn. i removed the rear slip diff assemble and it began its working fine. however when I put the assembly together it skips as I turn the wheels. I put everything together and now when i turn the wheels , front or back the center drive shaft and, spur gear and pinion dont turn. what could be the problem. could it be that my slipper is too tight. I back it out one full turn
    I play til something breaks
    Aug 2012
    central nj
    51
    rear diff bearings,sounds like what mine was doing when they went bad
    Jul 2012
    Saint Louis, MO
    504
    Check the bearings in the spur assembly.
